375hp banshees
    209
Everything posted by 375hp banshees
  1. ^ all of it i'll bet Sent from my SM-A505U using Tapatalk
  2. Any change @ all with other jets. Post a pic of carb #'s . is it the same set up as before new top, or is it new/ new to you? If you think it's reeds swap side to side n c if prob. Follows Gotta use tapatalk for pic's Sent from my SM-A505U using Tapatalk
  3. Trial & error was with oem ignition? What did it do differently leaner & richer? Niche top end? Genuine carb. ?
  4. Hopefully atleast 1 was or he might be in for a tyler kinda ride...might be anyway Sent from my SM-A505U using Tapatalk
  5. So when you said your slides were fine...at least 1 wasn't up?
  6. Seat bouncing ftmfw
  7. iirc, been a minute, dont think there was a gasket ( not sure) and it looks like its welded twice there. these are from my cpi's. fattys look completely different. Not much help, been a long time since i repacked, but seems like the pipe continues inside where its full of holes . gonna be hard to repack now. Does the other end have these caps too? Sent from my SM-A505U using Tapatalk
  8. Might save you some headaches. they seem to have a good reputation but I've heard nightmares of people with PVL's and stuff starting off on a new build.doing just an ignition change On a currently running eng. might be a better start... Downfall is, you might end up buying 2 Sent from my SM-A505U using Tapatalk
  9. New build or already got time slips/ jetting to compare? Sent from my SM-A505U using Tapatalk
  10. Dasa 'ol one Sent from my SM-A505U using Tapatalk
  11. Tru try sand drag addicts too den Sent from my SM-A505U using Tapatalk
  12. Fixed? Somebody else will have to answer that I've never had stock carbs 1of your text said something about 22's, stock are 26 I don't know if that was just lost in translation or... Sent from my SM-A505U using Tapatalk
  13. Yep it had it from the factory then... very common problem Sent from my SM-A505U using Tapatalk
  14. Try bhq facebook or atvdr facebook. might be some old schoolers on there thats familiar with it Sent from my SM-A505U using Tapatalk
  15. Это было только в более поздние годы, какой год твой Sent from my SM-A505U using Tapatalk
  16. нет выключателя сцепления / стояночного тормоза (левая сторона) Sent from my SM-A505U using Tapatalk
  17. That sounds like your parking brake rpm limiter ...what year is it. There are lot of knock off carburetors that are junk. they look identical except for certain things ,that some people know how to tell the difference. I'm not sure if they make Mikuni knock offs or not Sent from my SM-A505U using Tapatalk
  18. Can't see video of contamination Contaminated with what? are they genuine carburetors or cheap eBay
  19. You dont think new one is bad do you? Sent from my SM-A505U using Tapatalk
  20. ? Sent from my SM-A505U using Tapatalk
  21. 37 + - 5 Sent from my SM-A505U using Tapatalk
  22. Need better brakes...or you go to school in NC
  23. I would think if the mc was bad youd have play in your handle... Maybe not Sent from my SM-A505U using Tapatalk
  24. On second thought , gently loosen up banjo @ mc after its locked up & see if it frees up Sent from my SM-A505U using Tapatalk
