375hp banshees
    209
Everything posted by 375hp banshees
  1. If you think it's flooding. Shut the fuel off and see if it gets better when it gets low
  2. Long shot but try with choke on & see if it starts firing also bowls on correct carb?
  3. Explain set up for Going from? Stock port timing ? Pistons used? Domes used? Does it pass leakdown now? Case seems fine as in no rod sticking through & guessing...Damage found after?
  4. Keep all dem damn marbles inside fo sho Sent from my SM-A505U using Tapatalk
  5. @Sway what do you mean tested the water...test rode or literally ? Sent from my SM-A505U using Tapatalk
  6. @gusto it also broke head? & plugs backed out... then later the head busted, blowing o- ring out? Sent from my SM-A505U using Tapatalk
  7. Fuel & compression? What do the pistons look like? Sent from my SM-A505U using Tapatalk
  8. Did you do a leakdown Before after now?[emoji848][emoji848] Where did you read if plugs back out change pilots.[emoji2955][emoji2955] Did it blow oring/ start blowing our radiator, as soon as you fired it up w/ dif. pilots, or after you rode it a while with dif. Jets?[emoji3062][emoji3062] What size domes& main jets, timing?[emoji846] Sent from my SM-A505U using Tapatalk
  9. Not if your cylinders are stock or not ported for it. Is the piston # the same as one you pulled out? How did you end up with those new pistons? Sent from my SM-A505U using Tapatalk
  10. Сторона, которая не нагревается, не получает топлива. попробуйте потянуть воздушную заслонку с этой стороны и посмотрите, поможет ли это. если да, то с этой стороны что-то забито в карбюраторе
  11. Not tapatalk...say it aint so Sent from my SM-A505U using Tapatalk
  12. He's not from Missouri geeze Sent from my SM-A505U using Tapatalk
  13. Yes, no need to take all apart, just enough to r&r bushings Sent from my SM-A505U using Tapatalk
  14. Or try this? Dennis?? Sent from my SM-A505U using Tapatalk
  15. XFR nerfs are nice, but have to heal kick
  16. touché Sent from my SM-A505U using Tapatalk
  17. Yeah tubez n boobiez ...are different Sent from my SM-A505U using Tapatalk
  18. I wouldn't give him shit...just anti seize the shit outa the tube @re-assembly Sent from my SM-A505U using Tapatalk
  19. Keep the nut on loose( to spare the threads,) and smack it, and then hit the head of the bolt/ nut Back & forth, lubing as you go Sent from my SM-A505U using Tapatalk
  20. Just anti seize the shit out of bolt & sleeve. I think most just make outer tube /swingarm greasable
  21. Work around is legit Go to chrome://flags -Search tabs -Tabs grid layout: default- disabled -Relaunch -repeat- back to default, relaunch & it defaults to cascade rather than block...like it's supposed to
  22. The New android/ chrome updates have problems. one is the default view of tab's that are open, not defaulting to cascade, rather its in block view ...which i hate. I found a fix, but seems suspect Sent from my SM-A505U using Tapatalk
  23. Anybody do any of the fixes for this "new" update I found a fix to put windows back to cascade, but it has a BIG warning so...somebody else do it 1st [emoji3166] Sent from my SM-A505U using Tapatalk
