Everything posted by JET 99
i finally got mine out for a few minutes.. in some virgin dried up dirt.... i tried to take off like i used tooo..... hehe :ohmy: i blipped it a couple times. 2nd gear... dumped clutch pinned it... spun about 10 ft.. hooked up.. and proceded to pull front tires up.. was seating up with chest over bars... just like i used too... rode it out a little let off and tried a few more times.. same result didnt want to piss neighbors off.. so headed home... with a big ass grin on my face.... :biggrin: pretty sweet power.. 33 pwks,noss 20cc,.020 bore,w&t crank,tz bearings,his all over power port job....... :thumbsup: :thumbsup: :thumbsup: ,v-3's,inter cross-over intake,case port match,jeff's h-d clutch set up,shift shaft mod & spring,k&n's w/outerwears,nology coil and hot wires... i am very pleased with the outcome.. oct 19th i sent him the motor.. and in late january i got it back without any problems....... jeff is fine builder.. and his work speaks for itself..
TORE APART SHEE LOOK WHAT I FOUND
JET 99 replied to HARRY64CHEVY's topic in Banshee Repairs and Mods
the man that replied to your question above is quite capable of doing both!!!!! :thumbsup: his name is jeff. he is the man behind fastoys...... -
what brand machine tools do you program? lathes,horizontals,verticals etc... just curious, i am on the flip side doing machine repair of cnc tools mostly mazak,okuma,warner&swayse,cincinatti.... (electrical,mechanical,pneumatic,hydraulic)installation,fabrication..
thanks, jeff has the price listed on his web site(banner top page of hq forums most times)yes rocky mount acerbis unikos..... wiring no not hard.. low beam pos + and black= ground. later i would also like to run a set on handle bars with high switch wires.. should be able to run both with 200w stator...
reckin dat dar famlee tree luk like a dang telefon poll...... :yelrotflmao: :yelrotflmao: :yelrotflmao: :yelrotflmao: bet r u watch ur sellf loco he mite haav sum kin in ur woods......
heres a pic of the torch lites.. jeff at fast sells them ..... got em when he had my motor.... yes he is the proud creator of another sweeet!!!!! shee motor
sounds like somebody is trying to start a circlejerk.. and i aint talking bout the band either........ :shoothead: :shoothead: :shoothead:
hand to gland combat ....... beat the soldier tell he pukes :woot: :woot: :woot:
mine does see pic above............... :beer:
bet you could talk to jeff at f.a.s.t., he would steer you in the right direction.... :beer:
damn son you riddin in antarctica?????????? you said it was cold, but freeze the gas line........ :miner: :miner: :miner: :beer:
what your talking about is the cross over tube. you can waste 30.00 on a boost bottle there. you can leave it stock, you can get an internal crossover like boss,or some seal them off.. :beer:
not yet, guess thats why i am doing this... weather is supposed to take another shit.... fired off an email to jeff.... now would be a good time for nology coil and to actually get some pipe clamps. i am going first chance i get to the badlands and see what its like........ figured i would do it before nicer weather gets here!!!
mounting and wire route used a piece of heat shrink tubing for wires by handlebar wire to blk/wht... black to black splice.. finished .....
my dog ran off with the plug ...... right after i snipped it off..... :biggrin: :biggrin: :biggrin: :biggrin: :biggrin: oh well... thats why its a permenant mod...
you can still use the kill switch on handlebar... or i am getting ready to wire in kill tether cord too..... have read in here to use the kill switch wiring system to run tether.. tether is normal open so by splicing in to the black and the black /white wire you basically just wire in another switch when activated closes the circuit.... i will take some pics of this also....
heres a couple of pics on the wires to splice when removing key...... (99 wiring harness) the wires and plug. removing the plug. solder wires. slodering iron ,.032 flux solder,heat shrink tubing. end result.
i am with daj on this one too..... a little ounce of hi temp RTV (prevention),is worth a lot more than a pound of melted pistons (cure)new ones !!!!!! sorry fire head but i am disagreeing with you on another subject!!!!!!!!!!!!!!!!!!!!
nope just a deep freeze.....it only shrinks and expands so far..(i agree) its not the majic cure. but it does help... wasnt trying to steal the thread sorry... guess i will shut the f... up since i have no clue what i am talking about ...... :: :: :: :: hopefully some one will chime in and help you out :beer:
i am not talking about using a blow torch( setting bearings on drop light or oven at 200deg) just enough to open i.d. of bearing even (.0005 of a inch)can help i do this all the time at work. precision cnc machinery. even the manufacturers of tool machinery do it. i have been to a few maintenance classes at the machine tool builders facilties.. sorry i have never experianced a faliure because of installation... just my .02cents
i have access to a sand blaster at work.... save a bunch of time stripping it. the first time i tried primer and paint 1200 deg ceramic... it flaked off after a season paint was shot down by cylinders.. this time i went a head and baked paint like instructions say to make finish harder... so far it has worked... heat cycles of break in...... first couple of test rides... spilled gas on from filling tank... (dumbass) rode for approx 1 hr total... 20 min warm up and spin around block.. temp gauge has been up to 150 deg and no paint flake yet!!!!!! hope thats the trick.. or trade in for chrome ones....
not being a prick but wrong forum......... repair and modification would be the correct place to ask this question and to answer question pulling bearings off with pullers is best.. heating bearings and cooling crank off having arbor press ready to seat bearings would be best. but if you feel comfortable hammering on bearings.... you could beat with hammer and center punch i guess ????
i am not baggin on you specifically................... ok apply yourself for 2 more hours and be that much ahead of the game......... :beer:
no sh..... i worked 10-12 day during week.. 4-6 hrs saturday & sundays for about 3 months straight. and thats how i paid to do this .... and i still had a life .. went out with girlfriend,did stuff with son,feed dog,paybills,keep house clean,do laundry,feed myself,maintain truck, see my point welcome to reality ............................. :thumbsup: :thumbsup: :thumbsup: :thumbsup:
you dont think work gets boring ??????????? i dont care what it is .... scooping shit, to designing space shuttle parts.. you may like your job...... but after a while, maybe years, it ends up dulling out.. most jobs give you a lunch... hell even the marine corps lets you stop and eat, so where are you going with that??????? not saying your a troubled teenager :shrug: just dont understand your point of view!!!!!!!!!
