akita8
    Henderson NV
akita8's Achievements
HQ Soldier
HQ Soldier (2/5)
  1. Thanks Gonna put a set on the banshee
  2. Does anyone know if the Raptor 700 a arms are the same as the YFZ450's.
  3. 1.5L or 1500ml. Make sure you put it in the rt side. The clutch is on the rt and the the flywheel is on the lt side of the engine. Good Luck!
  4. Check your wires that run from the cdi at the rear of the quad, especially where they run next to the exhaust pipe. If the pipe melted through the wire insulation and is grounding out the wire it could cause the popping. iF you had your flywheel off recently check that and make sure the nut didn't back off.
  5. Spray soapy water on it and you'll find the leak. If it has small holes, slime works good.
  6. Where are you from? Maybe someone can give you a hand.
  7. Check your flywheel to see if its spun on the shaft.
  8. MIGHT WANT TO POST THIS IN THE APPEARANCE FORUM. IT TAKES LESS THAN A POUND TO ALL THAT.
  9. Sorry to here about your bike blowing up. Might want to check your coolhead orings, maybe you pinched one during install. I had it happen to me once out at dummont.
  10. Correct me if I'm wrong but the purpose of the overflow bottle is to give the hot radiator fluid a place to go when the temperature rises and as it cools it gets sucked back into the radiator. If you removed the overflow I guess you will have to check it more often.
  11. If you could send me some info Rabbit857. We first sanded the plastics with 320 paper and then cleaned with grease and wax remover. As for the paint we used 1. Plastic adhesion promoter 2. Urethane primer/sealer 3. Nason (dupont base coat) 4. Imron Clearcoat
  12. The stockers all get discolored and brittle. You made the right move and bought a billet impeller. Good luck
  13. Pull your filters off and see if your slides are sticking. If not check for an air leak with some carb cleaner or starting fluid around the boots and reeds. Just spray it around.
  14. Pull your air filter off and squirt some 2 stroke fuel into the carbs. If it try's to start pull your carbs and clean them out (especially the pilot jets).
  15. Thanks for the inputs. I think we're going with a silver/blue.
