sorry my explaination above wasn't very clear. beer and the internet don't mix! i'll give it another try.
here goes: For normal applications,the starter circuit or "choke",performs the task of administering the correct mixture to start a "cold" engine. what is meant by a cold engine varies greatly,between a motorcycle engine,which may only operate down to 40F and a snowmobile engine which can run at -20F. for this reason, the snowmobile carb is set up much richer than the motorcycle running the same size carburetor. this applies to the choke or starter circuit as well. this is often forgotten when someone tries to run a carburetor calibrated for a snowmobile on a motorcycle (or banshee!) and it floods out continually even when both carbs are the same size as the ones that were on the banshee or motorcycle. For this reason, the mixture can be changed,even the mixture for the choke. In the bottom of the float bowl passage,which feeds the suction tube to the mixing chamber for the choke, sits a small jet which controls the fuel flow to the choke. this jet can be removed and replaced by a larger one, effectively making the choke circuit "richer" for starting your banshee in colder weather. the reason the bike will not start in the cold is that the mixture for the choke is too lean. next time you have your carb bowls off look down the hole that the brass suction tube fits into and you will see the jet i'm talking about. again this may only apply to mikuni carbs. look at some of the parts break downs online on Sudco's site. it will show this small jet.
