pimpeinkc
Everything posted by pimpeinkc
  1. don't do it, my buddy did that to his and it never seemed right.
  2. you can call it smart ass, i talk shit too and i think of my self more as a dumb ass... but expect it here. lmao the 2 into 1 gives you more power, and is easier to work on....
  3. the valve has a grove in it, depending on which way it is that part is open, and there are 2 tubes inside, long and short, if you are running out with no reserve that is the problem, your short tube is gone, i would get a gas gauge to help you know when it is low.....lmao..... refill isle 9
  4. if it ran good last year, i would keep looking at the electrical, my warrior did that kind of stuff, try the brake deal, it got me, and then try the spark plug boot, they are 3-5 bucks, and that got me too....
  5. got a pic, not sure i am following ya, should be easy enough though
  6. i have the trail techs on mine and each bulb is 35 watts, they are bright and work great, plus they look cool,,, get them
  7. that is a bad idea, your street bike is a four stroke, and the oil lubes the head and valves,,,, you should think about switching to something heavy like 80-90 weight some thing like that,,,,,, like i said i use the honda 2 stroke wet clutch 80-90 wieght in the red bottle... my .02
  8. honda in the red bottle,, every couple rides
  9. they are a pain in the butt sometimes, but when they run, they run... good luck and keep us posted
  10. i don't know if you want to go this far,,, but,, this is what i plan on doing when i change out my sprocket, i did it on my warrior, haven't had to change it on my banshee or yfz yet... get some stainless steel nuts with the hole in it, then get some safty wire and tie them together,, i used to work on F-18'S in the navy and they had us safty wire most nuts and bolts.... all you have to do is wire them together,,, you can do two and then two,, or you can tie all of them in a row. up to you.. let me know if you need any tips or know how on how to do it..
  11. sounds like your compession is low, i run 21cc domes and i got around 150 psi.... might need new rings?
  12. i have heard good things about vito's pistons. they act like a port job without the porting..... i agree with the clean up on the intake and polishing the exhaust also.... good luck
  13. i run stock gearing, tried the 15 up front and if i was in the wrong gear, it would bog too much, i like being in third and being able to whip it around and not have to down shift.... other than that it worked great. wheelies out the hole for sure.
  14. were the reeds messed up after all, did you see any damage? that might not have been the problem it they looked okay..
  15. can't be good if it is moving the chain, i agree ,, start thaking it apart, it only takes a few. let us know.
  16. good point there, sometimes it rusts in there and causes bad pick up ,,,,,
  17. good luck, it is a lot easier then you might think, i did mine in like 2 hours,,,,,, not including the paint
  18. sounds like a plan,,,, you should draw it up and see what it looks like
  19. they look sweet, i now see the madness and it is awesome
  20. i like the black chrome, looks like smoked glass
  21. never had mine off, i do have some from my warrior i took off, i will try some methods with them and post results,
  22. looks good,
  23. i never cut plastic, but it sounds like it would be pretty easy... sweet
  24. that would be sweet. i just painted my cylinders and they look great. not powder coat though, i used caliper paint since i am crazy for brake cleaner and it eats most paint.
  25. i dont get the high preassure in there, i use chemicals on the motor. brake cleaner works good, just don't get it on plastic and rubber....
