PUSH THE THROTTLE
Everything posted by PUSH THE THROTTLE
  1. Updated list No Handed Lander - Completed Heel Clicker Can Can Nothing Superman Holyman Holyman over a 90ft gap to No Hander Lander w/o checking the bars Suicide Kiss of Death Tsunami Cordova Sterilizer Cliff Hanger Superman from rear grab bar Backflip Heel Clicker Backflip Cordova Backflip Superman Backflip 360
  2. Save a little more money and get ported.
  3. K&N http://www.magicracing.com/product.asp?itemid=827&catid=317 FOAM http://www.magicracing.com/product.asp?itemid=823&catid=317
  4. I disagree, This post has to be the least entertaining post you
  5. I use a dead blow hammer and tap the spindle a couple times while applying pressure to the arm as above pops right out. If you tap on the arms it
  6. I stripped a cheap (under $10) one once and then replaced it with a motion pro and haven
  7. Is that better or worse than red?
  8. Denton Racing Banshee J-Arm "Can you say "Awesome Handling Banshee", you can with our J-Arms. Complete with bushings for a bind free smooth action." Lonestar D-arms The lonestar D-arms are only uppers in stock length they have v-arms for extended setups but I can't find a picture of them. Edit: I still think a-arms are your best bet.
  9. Is an 02 a green or a red sticker?
  10. Denton racing had extended J-arms. Lonestar also had D-arms. You might check with them.
  11. I run mine with ported cylinders and it works great. The think the consensus is if you are ported or plan on porting you need to go with the 35mm instead of the 33mm. Now on the other hand if you think you might go to a stroker motor then you may need to go back to duals because the strokers really need to breath as compared to stock stroke engines.
  12. I run the 35mm CV2 really like it. It provides easy jetting (under 2 minutes for the main), thumb throttle feels like a Blaster so no more sore thumb, and the best part is they run great. Sredish is the man to talk to about this but he just sold his shee and has switched to the darkside (Honda) so he might not check in here as much as he used to. Singles are good for woods and tracks if you dune then stay with the duals. In my opinion definitely worth the money for my style of riding, farmland, woods and general dicking around beating up on Polarises.
  13. The real question is what the hell happened to Led????
  14. Are you talking new or used that makes a big difference in the answer. I assumed used in my above reply, if you
  15. I started reading that thinking WTF and then I got to the I'm going to eat him part and once I wiped the tears from mine eyes about blew my food all over I was laughing so hard.
  16. That bike needs some serious work to be as fast as a Banshee. My friends have Scrambler 400
