PUSH THE THROTTLE
Everything posted by PUSH THE THROTTLE
  1. That deserves 2 rollers
  2. Depends on your maintenance style, if you want to jump on and ride - 400EX. If you want to take care of your machine and jump on and WIN - Banshee. I
  3. I wonder why?? Not exactly a vette.
  4. Agreed, no point in adding power until you can handle it. And your body will appreciate a suspension upgrade.
  5. I understand your reservations but I ride tight trails all the time and when I finish my engine I'll be running my 16/40 again. You need to decide what gears do you normally ride in when you ride your trails? My guess is you're always higher than first especially with 13/41? If you up that front tooth count you can make a rideable first gear. For me my shee came 12/41 and I was running 4th-5th in my short straight aways and I'd downshift to high revs second for the tight stuff. With 15/40 sometimes I may shift down to first but for the most part I run in second and third on the same trails and do a lot less shifting and run much faster overall times. Take a shee out in the open geared 16/40 and actually hit sixth all your riding buds will have run out of gear at 4th. It's worth a try for the $12 for a front sprocket.
  6. This is the best way to do it other than wider arms. And on the back just switch your rims left to the right and right to the left so your valve stems are on the inside you will widen your rear end for free no wheel spacers needed.
  7. My advice is slap a 15 tooth on the front and give it a try, you might be surprised at how much you like it.
  8. The Lord works in mysterious ways. Sorry to hear about your loss.
  9. Don't kill yourself. Keep the tricks coming guys I'll update the list sometime and I'll put completed next to the ones that Freestyler posts pics of. Might have to help me out with the names though I'm no expert.
  10. 1. Hold the rear brakes while you break it loose. (cheapest) 2. Impact (easiest) 3. Shove a punch through your rear sprocket and through your brake disc it will lock against the swinger make sure you don
  11. They are more or less grouped beginner-advanced-pro not in an exact order. He needs to start somewhere and a Heel Clicker is a good start. Get us a good picture.
  12. So what are you going to go with?
  13. Freestyler, I
  14. Led for HQ Awsome Picture award.
  15. http://cnn.netscape.cnn.com/ns/news/story....0&w=RTR&coview=
  16. I replaced my coil when I got mine didn't fix it. Then I replaced the CDI and it ran great for about a week then in the middle of the ride it shut down with no spark. Replaced the stator and no problems since. All these electrical parts need to work together or else you are chasing your tail. You fix one thing it works great but then the next thing fails. I say replace it all and be done with it.
