Banshee~
Everything posted by Banshee~
  1. Will the cdi box work on a warrior? How much?
  2. Get the scratch free sos or scotch brite pad.
  3. Id would take the lid off all the way and then put in some 330 main jets. If those are to big then 320 main jets will be perfect. Then put in some 27.5 pilot jets (one size bigger) and leave the needle alone. You might not even have to change it.
  4. Id wait untill you finish breaking in the motor before you start dicking with the jetting and oil mixture.
  5. 320 mains 27.5 pilots middle needle position 1.5 turns out on the airscrews
  6. Me because I have a redbull can on my shock resivor
  7. Your lean...put in a 320 main jets and 27.5 pilot jets. Those bras air screws adjust 0-1/8 throttle.
  8. Yea exactly if your going to start shit. Im sure you dont go around starting shit on E2S.com do you? Your just trying to get in a pissing match...my banshee is cooler than your banshee blah blah blah.....
  9. make than anything dg sucks ass
  10. Losen those nuts off all the way (counter clockwise) before you take the wheels and tires off. I used a big fucking pipe wrench and put a two foot pipe over the handle to get more leverage on them. When you put them back on put alot of lock tight on both axle lock nuts . http://www.bluetraxx.com/ go there and then to tech tips, then look under rear axle bearing replacement for a guide. Also, use your clymers manuel.
  11. Ive had good luck with that oil. I want to try ben oil because it smells real good, but on the back of the bottle it says you cant run the oil under 35F.
  12. Id say that would be your problem...holding it wide open that long is not good for it. It will overheat faster than way and you could seize a piston. Engine Ice, Noss machine coolhead, and a mega flow impeller are all good things to put on your banshee.
  13. What did he say to you? Did you ever get the job appliaction in the mail? Id give up my whole summer break to work for $50 an hour, anyday. It beats $6 dollars an hour that I worked for last summer.
  14. Happy B-Day Bro hows the honda?
  15. I took mine off and just check the coolent level in the radiator every other ride. Some times I add a little bit, but I havent had it overheat once since I took it off. Things that will help cool your banshee better 1.engine ice 2.mega flow water impeller 3.noss cool head 4.bigger radiator
  16. one hour left
  17. No bidders yet bump.....
  18. These are mine im selling http://cgi.ebay.com/ebaymotors/Yamaha-Bans...DVW%3Cbr%20/%3E
  19. Passion Racing Engines Tulsa, Oklahoma Telephone: (918)272-5665 or (918)232-3950 email: [email protected] thats all I can remeber from the top of my head
  20. Good, go back to everything2stroke. Are you not the moderator over there? Dont they stay out of fights and try to resolve them? yfzut do what you want with your banshee/yfz I think its cool and post pics when your finished.
  21. Put it on ebay http://cgi.ebay.com/ebaymotors/Yamaha-Bans...sspagenameZWDVW
  22. I have one also and it covers everything. Only complaint is that I had to modifiy one of the tabs holding it on.
