banshee tuner
Everything posted by banshee tuner
  1. Mine will not crank without silencers.
  2. I would stick with the +4 timing and run race gas, but that's just my opinion.
  3. It sounded like they were screwing you every since the original post you started. I would go talk to a lawyer but it is hard to beat a mechanics shop in court. Report them to the better business bureau.
  4. I'm at sea level and I run 310 mains, 27.5 pilots, and needle clip in the fourth position.
  5. 02 was the first year.
  6. Yes I say 2500, depending on the looks.
  7. I have the motion pro and it is great.
  8. I've got clear 1/4 inch on mine for fuel supply but bought some 1/8 line for the overflow but it is way to small.
  9. Try unhooking the tors.
  10. Eigther the reeds are stuck open or the float in the carb is stuck or set to high.
  11. If your not into some sort of track racing or cross country you don't need them.
  12. I have never run them on mine because I don't need them, plus it is easy to go in reverse with having more open space. If I motocrossed or tt raced I would have a set.
  13. You can bump your price a couple of hundred but you will probably have to settle for what you paid.
  14. If those plugs are not the same color you created an air leak with the boost bottle or the reed spacers.
  15. It's easy to install, just replace the stock balance tube with it. Some banshees it helps and some it hurts throttle response.
  16. Nice shee, good luck on the sale.
  17. Thanks for the pictures.
  18. Take a look at the pickup coil by the flywheel, make sure it is close enough or is not corroded.
  19. That is a neat looking set of arms you have.
  20. So it looks like that rolled edge holds up well. I had a set of douglas .190 with sanddevils but they were heavy. I've ridden the same places and the rocks dented the douglas and just scratch the stock ones, but I have never weighed just the rims though.
  21. I don't see how he took that.
  22. I would only pay that if it had a lot of nice mods.
  23. I run maxima chain lube and wax and mine has held up for 5 years.
  24. The front comes up easier on mine with stock gearing but 15-41 smoothes it out where I can hold it up longer.
