wesw
Everything posted by wesw
  1. what yr is the cdi box off of and how much also can you get a pic of the plug that hooks to the main wire harness. thanks
  2. first off are you running duals now or what. you say pwk then its carbs pural. meaning more than one correct. i take it is duals. you need to see what needle it has. 50-55 pilot, depending on needle 3/4 clip. and 150-155 mains. youll need to sync the carbs good also. jeff has that tool you can get. should run well. might have to adjust a bit.
  3. their called grand rivers racings. grr sucides
  4. what size of tires are you running 22,20 what. you should be able to run 20s easy with 13-41. with a port job you should be able to run 14-41 with 20 and take off in sec, should???
  5. nah dont worry about it theres a fastenal bout 45 mins away ill just go there. thanks anyways
  6. have a stocker perfect shape simple shipping and its yours. wes
  7. it was me and ill give 10 for them
  8. only thing better than reading this story was if it was on video and you throw that guy that would have been priceless to watch. gotta love a good fight were they start shit and you finish it.
  9. if your talking about shifting while slipping the clutch going wot. did it for 1 or 2 yrs. didnt break anything not saying it wont.
  10. towards the end of the nite drink big glass of water and eat some stuff. bread type of stuff absorbs the booze pretty well.
  11. pics of swinger????
  12. your probably going to need a program to resize them to make an avatar. if you dont have one email me or pm me i can resize it, then you can save to your harddrive and then upload it. if you want.
  13. 60 psi sounds like they are junk or something is wrong. you need to check ring gap. and mic the jugs for straightness. i wouldnt run it unless it had 120 psi with the 20cc i see in your sig. jetting yeah thats way to big. try 27.5, 4th clip and some 360 work down my guess. but first fix your compression stuff.
  14. i hear you there jeff. i think it dynoed at 75hp with cpi. was a pretty mean little motor. some one is going to be happy.
  15. why you selling them jeff??
  16. thats all i ever offer. :yelrotflmao:
  17. show a pic of the exh looking down thru the middl eof the bore. and some of the transfers if possible.
  18. i think they pull in the mid more. shearers will pull more on top. i guess you could try them and if you dont like them they will guarentee them so they might take them back grr that is. or some shearers.
  19. unless your rich and want new stuff i think your ok. just tell your builder what pipes you want and what you ride at you will be ok.
  20. pick pipes for what kind of riding you do. your pc are like an all around pipe. like a t5. should work for most setups. you have to say what riding you do. pc should work for about what ever you want unless your going full drag setup.
  21. your talking about itunes music right?? sorry for the dumb questions.
  22. im a tight ass i get my stuff from limewire. so itunes will burn a mp3 disc. just as long as it not purchased from them.?????
  23. remove teh cable off the arm by the cases, with teh clutch cover off and what not, have someone or yourself push the arm to wear the arrows line up on the case and the arm. then tighten the tension screw up till its tight with the arrows lined up. then lock the nut tight against the screw. then put the cable back on and adjust free play.
  24. ok i want to burn mp3 cds with like 200+ songs. what program are you guys using. i dont know if ITUNES will do it. i used to use real player but they charge months access to burn premium cd features. thanks.
  25. what one now?????
