redcell43 Posted November 20, 2005 Report Posted November 20, 2005 need to know teeth for front and rear. not much draging more playing out in the dunes. i was thinking of 43 or 44 rear and a 14 front. with a non o ring chain. and another question what is the best chain to buy (brand) non oring and what length for stockswing arm. thanks Quote
odaen Posted November 21, 2005 Report Posted November 21, 2005 (edited) With a piped banshee, I'd run stock gearing with some 20" haulers, or even jump down a tooth in the front. I've heard somewhere, may have been here, that running a larger front sprocket and going larger on the rear to accomodate it will improve your chain life from not being stressed with such a tight radius on the front sprocket. oh, and the ERT chains from DID are non o-ring, and hold up rather well. Edited November 21, 2005 by odaen Quote
TheBansheeMan86 Posted November 21, 2005 Report Posted November 21, 2005 just curious whats the difference between running a non oring and an oring chain? of course other than the presence of the orings. is it just the cheaper way to go or what? i run a DID Gold X-Ring and love it. Quote
redcell43 Posted November 21, 2005 Author Report Posted November 21, 2005 So number of teeth on the front and rear is? Quote
iceman Posted November 22, 2005 Report Posted November 22, 2005 put 1 in the front and 0 in the back look. http://www.everything2stroke.com/resource/banshee.php infinity mph in every gear. youd never have to shift! Quote
Ducman Posted November 29, 2005 Report Posted November 29, 2005 I run PRIMARY DRIVE sprockets and gold o-ring chain that rockey mountain atv sells. Inexpesive and good quality. Stock chain size is 520x104 length. Most non o-ring chains will stretch like a MF'er on every ride requireing a lot more adjustment and wear out much faster, like 4x faster. I like the Gold chain because it doesn't rust and is easier to clean. With 20" tires in the sand I thought the stock 14/41 gearing was just a tad to tall but 13/41 was geared down too much except for long steep hill climbs. I like my 13/41 now with 21x12x8 9p extremes. So I would recommend about 14/43 with 20" tires. For me, I did better on steep sand hill climbs when I geared down but for typical play duning it was a little low geared so you had to shift alot more. Higher or Lower gearing has its advantages and disadvantages, you just gear it towards the type of riding you want it to perform best. Quote
Justintoxicated Posted November 30, 2005 Report Posted November 30, 2005 (edited) Piped banshee with Skate II's I liked 13 41. get a DID X-Ring chain. Edited November 30, 2005 by Justintoxicated Quote
23champ Posted December 5, 2005 Report Posted December 5, 2005 I run 15/44, with DID ERT chain, it seems to work out really well (same ratio as stock). Quote
jaysea1 Posted December 5, 2005 Report Posted December 5, 2005 AS stated above go with an X ring chain or O ring chain. I use the DID X ring chain. Much heavier duty than the cheapy non o ring DID chain I used before. I only ride in the dunes so I thought sand would get into everything, so the chain did'nt matter. Like Duc man said the non ring chains stretch all the time and don't last as long. Quote
knight_ripper Posted December 29, 2005 Report Posted December 29, 2005 there can be only one sprocket. www.sidewinder.com guaranteed. Quote
bansheeigo Posted December 30, 2005 Report Posted December 30, 2005 Thats right sidewinder sprockets are the best,i got a front and back ti-moly sprocket and a stainless steel chain.its better if you buy a package,sprockets & chain. www.sidewindersprockets.com Quote
jprog7 Posted January 13, 2006 Report Posted January 13, 2006 I run 15/44, with DID ERT chain, it seems to work out really well (same ratio as stock). 444998[/snapback] Just curious, how many link chain are you running? I'm assuming you are still running a stock skid plate?? Thanks, Jeff Quote
shanYE west Posted January 28, 2006 Report Posted January 28, 2006 My vote definetly goes to sidewinder I use the ti series non O-ring I use 15/42 or 14/40 for duning.. Depends on your motor mods Stock motor I would use between 14/42 to 13/42 Quote
Shee-Male Posted January 28, 2006 Report Posted January 28, 2006 DID X-ring w/ sunstars 15/41 mostly trail & love it. Quote
sandman Posted January 29, 2006 Report Posted January 29, 2006 13/41 D.I.D o-ring with Sunstar sprockets. Piped shee in sand w/skate 2's. Quote
