Everything posted by knight_ripper
I didnt have any luck with the cheapies. Im not stock tho either. I have a Trinity or a Toomey in mine currently. good clutch.
possible you bent your brake rotor? possible your hearing your caliper rubbing or banging on it. mine rubs pretty loud. but if its bent will give off a banging or clacking noise. also check your bolt that holds on your swingarm. bearings could be bad and thats what your hearing. but it only makes noise when turning right? which means its putting pressure on the left side rear? could be your chain too. is it clickin on your sprocket? if your chain is too tight it will give off a clicking sound too.
albaaction.com will hook you up with a full set of stickers and kits. give um a look up.
Bel Ray FOREVA. buy it in bulk straight from Bel-Ray. I use their 80w tranny oil, H1R synthetic mix and dot 4 brake fluid. good stuff. my banshee is a 97 and Ive rebuilt the top end once three years ago. Shee was 1 thousandth out from stock specs so I put in a 1 over piston and rings. never replaced the rings before that, and shee still has 120psi per cylinder. my mechanic told me not to change a thing.
Ive tried the same.....TCS is what I have on my banshee. I used to have Works. And I have Elka's on my 450r. Anything is going to be an upgrade from stock shocks. In fact I didnt even do any adjusting on my first pair of aftermarkets cuz they were so awesome compared to my stock's. I put a generic set of +2 Works with resi's on first. they were the sheet. and cheap too. then I upgraded to TCS. I wasnt that impressed with TCS's service and customer support...heck ... with I wasnt impressed with their rider support program either. they I got my hands on a set of Elka's. have to say that these are the best to date. I have them tuned killer and they work AWESOME. My next set of shocks for my next stock bike will be WORKS. just cant beat the price and the shocks are killer. great shock for the money. ELKA's if you have the change. Ive also read great things about PEP's. never heard anything negative about them. but I havnt riden on them. I Race. Used to race MX and XC. Now pretty much just desert. But I dune and trail ride here in nor cal on all these shocks. Elka's take lots of adjusting before they are set up right....but the works are pretty much plug and play. i just dont want peps spending lots of money on shocks they cant set up to begin with. would be just a waste of money.
ALSO...on a serious note. you can replace the steering stem bearing....and loosen the clamp on the stem. also....you could get a steering dampner/stabilizer and that help's alot too. I put a GPR on mine....and it took away all my arm pump.
janssen sells an enclosed Heim. awesome setup. and your heims wont come apart while your riding anymore. just ask me how bad that sux. lol.
little history. the other day I posted some stuff in regards to this problem. so...in the middle of a desert race the shee started to loose power....then bogged out and stopped. got her home and took off the air filter. and low and behold two reeds broke off and one of them a V-Force Reed was lodged in the carb holding the slide wide open. (never found the other reed) After shee sat for 5 months, I replaced the cages and reeds with V-Force 3's. replaced the gas in her, replaced the spark plugs and fired her up. shee ran for about 100 yards and then I heard a loud puff...kinda like pressure release....I was slowing down and downshifting to flip a bitch when it happened...so I heard it pretty good. then I gassed it and shee started poping or puffing and sputtering. got her home...checked all connections, hoses, changed fuel filter, put in new plugs and verified that the slides were in right. fired her back up and still the same. as shee is sitting there warming up the right side (same side reeds blew out on) gets real hot while the left is still pretty cool ... if not cold. then if you give it a little throttle....the left side blows a steady stream of smoke and the right side sputters and puffs or backfires plumes of smoke. the more you gas it the worse it gets. again...shee was running great before this happened and according to vforce no jetting should take place. so I dont think its a jetting issue. i went ahead and took off the carbs and cleaned them out real good...replaced them and same deal. ANY IDEAS? im all out. Im thinking the other reed went out the exhaust. what if anything could that have hurt. maybe its still in there...maybe its blocking something. Im at a loss...no idea. HELP!
i bought +2's for my front end. and they too were way too long. I had to put a loop in them and later rerouted them. I felt I could have ordered stock length galfer's for the front end and would have been fine. get +1's to be safe.
Sputtering and backfiring in midrange
knight_ripper replied to knight_ripper's topic in Banshee Repairs and Mods
oh great now im really confused. lol. on the backfiring thing. Is there a difference between a backfire and a poping. I want to record my quad running and get it on here for the pro's to listen to. carb's never have been my strong suit. i was noticing yesterday .. .that my left plug is half black and half milky...and the right plug is black as black gets. thats why I was lookin at the carb sync. I guess I could have an air leak too. weird that sitting for a few months would do this. I thought it was the V-force 3's. but im starting to doubt that. I still have my stock stator. changing it out wont be an issue. jsut have to take her apart again. thanks for the help bro. -
ive been reading a ton on sync'n. from what I gather its that little nut on top of the caps. Im going to do mine tonight. I hope thats it.
i read about that slide issue. I will check them tonight when I get home, to verify that they arent backwards.. they should be right. I always take them off one at a time to keep them straight...but ya never know. also....rs stator....ricky stator stator. well known stator. i brought up the +4 advance, cuz I read where some people advanced it too much and got backfiring and so forth. -
three part question. any chance carb's outta sync would cause this reaction? I know my right one is just a pubic hair before the left. You can see the white in the one window and not the other...a little more throttle and the line is at the top of the right carb window and the left is at the bottom of the window. is that accurate enough...or should I sync them. second question....how do I raise and lower the slides to sync them? no tors...just caps on top carbs. third question...if my needle is the problem....which way do I move the needle to lean her out. reading all the threads on here...Im thinking Im too rich. which is causing the bogging, sputtering, and backfiring. move them up or down? im thinking moving them up will richen the carb mixture...and moving it down will lean the mixture. -
In the desert shee is the fastest around. I would pass 4 strokes in 6th gear on straightaways....but they would always catch up in the rocky sections and turns. same with MX. kicks ass when your on the throttle. nothing can touch it. but once you get into tight turns the 4 pokes would pass me by. I have never taken worse than a 3rd place finish. been racing 5 years. Also with the 5.6 gallon tank I would pass peps in their pits. I loved the distance that tank can take me. over 100 miles.....Id always fill up round the 90 mile markers. Also....i stoped racing her cuz its just too tiring compared to the 450r. the banshee is a rocket. constant pull on my arms and body would tire me out. specially on the track. cuz it has such thrust. now on my 4 poke I can race all day. well almost...hehe. but really, the power ban is spread over the whole gear versus....wham power....like the banshee.. Also...the turning. with newer bikes your looking at todays geometry. versus a banshee's ... which is what? 1986 geometry. so with the new 4 poke I can ride longer, with less body fatigue, and with this thing built by ALBA and Honda....it keeps up if not passes every quad out there. no porting or polishing on either vehicle. the 450r was Wayne Matlock's '06 vegas to reno bike. He is honda's pro rider. It was built by honda's guys and pimped out by ALBA. wayne and a guy from honda dialed in the suspension and I have to say its the most plush ive ever riden. NO BODY ROLL. It was put in ALBA's showroom right after he took 1st place in that race. just waiting for meh. lol I picked it up with all the trimmings at a great deal. its a smokin ride. after riding my shee for so long... I couldnt go to a stock bike. the 4 stroke I got had to be off the charts...and this bad boy is just that. ive had 2 races on her so far....I took 2nd in my first race and 1st in my second race. vegas to reno is in a month and were entering it. fingers crossed for another first place finish. -
i usually have to tap them pretty hard sometimes with a hammer to get them out. they sticky. new gaskets come with new reeds. they are cheap from Yamaha too.
I have advanced my RS stator to +4. I wonder if changing the timing will affect the sputtering and backfiring. hmmmm. -
ALL KINDS OF QUESTIONS PLEASE HELP!
knight_ripper replied to dwrracing's topic in Banshee Repairs and Mods
i pretty much have the same setup as your buddys. I am running my timing plate at +4 advanced. also my main jet is an 062 and im on the second notch on the needle jet, idle screw 2 turns out. I run between sea level and 7000 ft with no jetting done. runs great at sea level....although I run 50/50 gas. Runs like sheet up at 7000ft...but I mosey along. I am however running Moose Needles. I had to switch over due to problems with the stockies. shee runs way better with the moose. I think they are tapered differently. hope that helps. not sure about your rid. I havnt steped into port and polish yet. I think the dome sizes directly affects gas tho. If I remember correctly ... if I was to go below a 21cc dome I would have had to run 50/50 all the time. go lower and your steping into 110 octane. -
some history. Bike ran killer, for the past 3 yrs. Last race I blew out two reeds on the V-Force 2 system. On right side carb. Wouldnt run....took me out of the race. In same race my frame broke in two places after the IMS oversized tank mounts busted on one side. I said fuk it and kept going....thats when one side of the steering frame broke...then on last lap other side broke. then the reeds went. I had slowed considerably after the frame broke...I thought I was having an overheating problem...but turned out to be the reeds. It was in the 100's out in the desert that day...I was on mile 90-105 when shee broke. only 30 miles to go. SUX. got home, took off air filter, only 1 reed found (dont know what happened to the other one). Found 1 reed in my carb completely verticle holding up the slide (open). Replaced with V-Force 3's. 5 months and a new 06 Honda/ALBA built 450r later (racing only) . Now the shee is trail/dune only. I finally got around to messing with it the other day. first thing I emptied out the gas. Filled with good stuff. Changed spark plugs. Changed fuel filter. Put on the new reeds. took her for a spin. Shee ran for about 15 minutes real stong. i liked the new sound from the V-3's. then bam....I was downshifting ... turning a corner. when I came out I gassed it and she started sputtering, backfiring, and wanting to cut out (but not dying). took it back....cleaned out both carbs. started her up....shee idles....shee runs thru all gears 0-1/4 throttle. but the second you gas it....sputter sputter pop pop. If you massage the throttle.....wam shee takes off almost throwing me off the back. and sputters almost instantly. then gas it agian....seems like it has some throttle in there ... but not enough to get her going. did compression test.....120 PSI per cylindar. any ideas? Im thinking needle jet. I called v-force....they said the same thing. but they also said that the system shouldnt require any jetting. specially going from 2's to 3's. HEEELLLLPPPP.
broken V-Force reed ---help
Ask and ye shall receive! thanks Paul. I will be making that purchase as soon as I get paid. thanks for the help. -
yup...thats what Im seeing. Im looking for replacement reeds for the VForce2's. but IM NOT finding them. Do any other carbon reeds fit in the VForce cages? Anyone know where to get the replacement reeds? -
Ok.....a little history. Reeds are about two years old. well...two racing years. During my last race....Around mile 60 on a 66 mile race (sux) the shee started boggin out. I was WOT and wasnt getting power. She was runnin...but terribly. Then died. Took off air filter to find Reed on right side inside the carb stuck holding up the slide. Well...Hello. Theres my problem. So ... two things. First, I want to understand WTH happened. Second, to fix it. Im wondering if they just broke? or something happened to them? do the reeds need TLC or something? I havent checked the reeds since replacing them 2 years ago. I figured the stockies lasted 8 yrs..... neway....I can just replace the reeds right? I dont have to replace the hole reed cage?
interested in the shifter...you have a PM.
MAN>>>>I LOVE Mine. wouldnt go back to stock if you paid me. I do 80 mile laps in my desert races. And the other weekend a buddy and I did 120 miles roundtrip. A stock tank gets 60-70 miles on it.....5.6 gallon 90-100 on it. way worth it IMO.
I have been runnig MAxxiS RazR II's. they are the most expensive. but they are way worth it. I will buying the same set once I wear these out.
Dont you mean DURA-BEND? Only one axle to buy. Lonestar. If you bend it ... they will straighten it for you for free. if you break it ..... they will replace it. I have been thru 3 axle's and they all suked! In fact...this past weekend I was in a crazy wreck.....end over end....axle is in great shape!....but my hubs are both bent.
