Does anybody have the Hydrolic clutch kit? My clutch is so hard to pull in compared to my Honda... Just thinking the hydrolic unit I have seen in the mags. will make a big improvement?
I have a Magura hydrolic lever and it works awesome but they are pricey. It is way easier to pull plus it is really nice and smooth. You can also get an EZ Pull lever to reduce the stiffness of the clutch pull. The EZ Pull are alot cheaper but I think the hydrolic is worth the money.
And they will not fit if you have large carbs last time I checked.
402447[/snapback]
yea, if you have otherthan stock carbs youll prolly need some reed spacers or different intakes thatll push the carbs back further. the hydro clutch had a master or slave cylinder whichever it is right down by the clutch arm..
I had one & must say while it worked it worked great. However one day it just locked up (couldn't pull the lever in) & I messed with it & messed with it & still couldnt get it to work. Now I have a ASV lever & cable setup. Love it. Still have the hydraulic clutch setup if you or anybody else wants it for parts.
