hotrodbanshee Posted December 4, 2004 Report Posted December 4, 2004 I did a topend rebuild and had alot of carbon in the exhaust port. I am also getting alot of buildup in my exhaust pipes from running castor 927 @ 32:1 Should I run 40:1? Will that cut down on the carbon buildup? Also anyone running the Golden Spectro syn/blend? I read on the bottle where it can be mixed 52:1 and it says it burns clean and won't carbon up. Would that be a good choice? Quote
SDD Posted December 4, 2004 Report Posted December 4, 2004 I run full synthetic oils for this exact reason. I usually run MC-1 or HR-1 oils anywhere from 32-50:1 depending on what kind of mood I'm in. You will have to rejet to match the new oil ratio though so be prepared. Quote
SICK BOY Posted December 4, 2004 Report Posted December 4, 2004 I run Motul factory line 800 at 60:1. Quote
FIRST BANSHEE Posted December 4, 2004 Report Posted December 4, 2004 klotz R50 32-1, smells gooooooood. Quote
banshee76179 Posted December 4, 2004 Report Posted December 4, 2004 klotz R50 32-1, smells gooooooood. 288621[/snapback] 40 to 1 here Quote
smokinwrench Posted December 5, 2004 Report Posted December 5, 2004 I run Blue Marble. It is just unreal the difference it made in how my motor ran. Here is alink to the website with some good reading info. http://www.off-road.com/snowmobile/reviews...e/bmoiltech.htm Quote
Holyman Posted December 5, 2004 Report Posted December 5, 2004 Amsoil @ 80:1 even in during the harshest winters at sub-zero temps. Dirt cheap too Quote
PUSH THE THROTTLE Posted December 5, 2004 Report Posted December 5, 2004 Amsoil @ 80:1 even in during the harshest winters at sub-zero temps. Dirt cheap too 289134[/snapback] I'll second that. Quote
joshv5.0 Posted December 6, 2004 Report Posted December 6, 2004 WD-40 at 32:1 289145[/snapback] yamalube at 32.1 Quote
03banshee04 Posted December 6, 2004 Report Posted December 6, 2004 amsoil 50-1great oil!!!!!!! just my 2-cents Quote
2004LEBanshee Posted December 6, 2004 Report Posted December 6, 2004 pb blaster at 40:1 289350[/snapback] Thought that was a blaster specific oil? Quote
