lastnline75 Posted April 2, 2019 Report Posted April 2, 2019 I damn close to an inch from touching. Still need to put on outer wears but they’re thin. Should I be worried?Sent from my iPhone using TapatalkDont worry...the wind will puff the Outerwears up an they will have a hole in them on the first ride...🤣🤣Sent from my SM-G950U using Tapatalk Quote
SKEETER Posted April 2, 2019 Report Posted April 2, 2019 1 hour ago, Ayesully810 said: I AM A HQ CAPTAIN, YOU ARE A SOLDIER. Cool story bro Quote
Canadianshee Posted April 2, 2019 Author Report Posted April 2, 2019 Damn!Get to wrapping, but you have a good amount of space. Sent from my LG-H873 using Tapatalk Quote
BigRed350x Posted April 2, 2019 Report Posted April 2, 2019 Just a heads up - if you use that fiberglass cloth style header wrap they sell at automotive stores, it will leave marks on your pipes after a while. I've used it in the past around the filters and it worked good, but if you ever unwrap the pipes they will have marks from the wrap that are tough to remove. If you don't ever plan to remove the wrap, then I would give it a try. worked good for me in the past. Quote
gusto Posted April 3, 2019 Report Posted April 3, 2019 10 hours ago, BigRed350x said: Just a heads up - if you use that fiberglass cloth style header wrap they sell at automotive stores, it will leave marks on your pipes after a while. I've used it in the past around the filters and it worked good, but if you ever unwrap the pipes they will have marks from the wrap that are tough to remove. If you don't ever plan to remove the wrap, then I would give it a try. worked good for me in the past. thanks 7 hours ago, locogato11283 said: NASA wrap. never heard of it. I will look it up. I want something that wont leave a mark on the chrome. Quote
ClaudeMachining Posted April 3, 2019 Report Posted April 3, 2019 Chrome = gay.We will look at your bracket soon my friend.Envoyé de mon SM-G965W en utilisant Tapatalk Quote
gusto Posted April 3, 2019 Report Posted April 3, 2019 1 hour ago, ClaudeMachining said: Chrome = gay. We will look at your bracket soon my friend. Envoyé de mon SM-G965W en utilisant Tapatalk Your jelly! i made the bracket already for the shifter electronics, I have it attachingibg to my air box tabs. what would be cool is if you could think of a bracket that can attach to my stator bolts that can hold the shifter Quote
ClaudeMachining Posted April 3, 2019 Report Posted April 3, 2019 Your jelly! i made the bracket already for the shifter electronics, I have it attachingibg to my air box tabs. what would be cool is if you could think of a bracket that can attach to my stator bolts that can hold the shifterI'll be your soon. I will have more time in a couples of weeks.Envoyé de mon SM-G965W en utilisant Tapatalk 1 Quote
trickedcarbine Posted April 5, 2019 Report Posted April 5, 2019 High heat silicon tubing from McMaster Carr. 1 Quote
375hp banshees Posted April 5, 2019 Report Posted April 5, 2019 On 4/3/2019 at 9:32 AM, ClaudeMachining said: I'll be your soon. I will have more time in a couples of weeks. Envoyé de mon SM-G965W en utilisant Tapatalk Summatime Quote
salmon_slayer06 Posted April 10, 2019 Report Posted April 10, 2019 On 3/26/2019 at 2:38 PM, Canadianshee said: Installed SLP pipes, I am wondering if a few layers of heat tape be enough to prevent exhaust melting pod filters. Install went smooth all the mounting holes lined right up after muliple adjusment. Any ideas appreciated. Sent from my LG-H873 using Tapatalk Been there done that. I didn't like it. Please take my advice get high temp silicone radiator hose to proper diameter and slip onto exhaust pipe only use enough wear it contacts pod filter. Been using it two seasons now no holes in filter.. 1 Quote
Canadianshee Posted April 12, 2019 Author Report Posted April 12, 2019 On 4/10/2019 at 6:27 AM, salmon_slayer06 said: Going to give it a try. There a few rice burner performance shops in town that should have what I need. Quote
trickedcarbine Posted April 21, 2019 Report Posted April 21, 2019 On 4/10/2019 at 6:27 AM, salmon_slayer06 said: This guy knows what’s up. Quote
