ClaudeMachining Posted November 18, 2018 Report Posted November 18, 2018 So, where it should enter/exit??? Envoyé de mon SM-G965W en utilisant Tapatalk Quote
locogato11283 Posted November 18, 2018 Report Posted November 18, 2018 You’ve got two holes in the head. Front and back. It goes in and out those. Quote
ClaudeMachining Posted November 18, 2018 Author Report Posted November 18, 2018 You’ve got two holes in the head. Front and back. It goes in and out those. I know. Thats not my question. Bill said the flow should be oriented toward certain holes first. I want to know wich one.I'll probably set an analysys for fun. Envoyé de mon SM-G965W en utilisant Tapatalk Quote
Canadianshee Posted November 18, 2018 Report Posted November 18, 2018 Keep it up Claud. Could you not improve your current design coolent flow, to allow less restrisive flow, since most are running higher capacity rads and improved water pumps. Sent from my LG-H873 using Tapatalk Quote
sheerider11 Posted November 19, 2018 Report Posted November 19, 2018 In, around dome, over holes, out. I'm sure the thermosiphon effect is working just fine in these that the coolant is moving. That's simplest way. You can make specific jackets that direct coolant directly into cylinders. Change design in cylinders of openingsBut get one of the thermostat heads. We aren't doing much just blowing water over it. You actually want to move heat. I wonder if we are moving the water to fast and can be more effective slowing it down maybe. But at the end of the day, there really isn't an issue. Some people over heat. But it's easily cured. So why beat your self up trying to change something that works? Sent from my SAMSUNG-SM-G891A using Tapatalk Quote
97Screamer Posted November 19, 2018 Report Posted November 19, 2018 42 minutes ago, sheerider11 said: But get one of the thermostat heads. We aren't doing much just blowing water over it. I've been considering one of the Wicked heads with the thermostats. You have any experience with or opinions about them? I don't know anyone who has actually run one. Quote
ClaudeMachining Posted November 19, 2018 Author Report Posted November 19, 2018 In, around dome, over holes, out. I'm sure the thermosiphon effect is working just fine in these that the coolant is moving. That's simplest way. You can make specific jackets that direct coolant directly into cylinders. Change design in cylinders of openingsBut get one of the thermostat heads. We aren't doing much just blowing water over it. You actually want to move heat. I wonder if we are moving the water to fast and can be more effective slowing it down maybe. But at the end of the day, there really isn't an issue. Some people over heat. But it's easily cured. So why beat your self up trying to change something that works? Sent from my SAMSUNG-SM-G891A using TapatalkThat's exactly what i think, my Noss head is doing the job as is. I personally think ( i didn't make any simulation) that what ever goes the water, it will cool the engine anyway.I just want to know what peeps are thinking about it.Im serious about making a simulation tho, that's been a long time since i made any CFD analysis, this one could be fun.Envoyé de mon SM-G965W en utilisant Tapatalk Quote
gusto Posted November 19, 2018 Report Posted November 19, 2018 Very interested to hear your findings Quote
JTmachining Posted November 19, 2018 Report Posted November 19, 2018 U should think bout some outside box shit. Get wid Zilla and RU Quote
specialblend07 Posted November 19, 2018 Report Posted November 19, 2018 Reverse the cooling?? Also have you thought about porting the water jackets, and making a head with larger cooling openings? Quote
ClaudeMachining Posted November 19, 2018 Author Report Posted November 19, 2018 Reverse the cooling?? Also have you thought about porting the water jackets, and making a head with larger cooling openings?The water jackets can be enlarged for sure.Envoyé de mon SM-G965W en utilisant Tapatalk Quote
ZillaFreak Posted November 19, 2018 Report Posted November 19, 2018 30 minutes ago, specialblend07 said: Reverse the cooling?? Also have you thought about porting the water jackets, and making a head with larger cooling openings? Been talked about. Didn't K+T post a video of them doing port work and porting the water jackets to get more/better flow into them? Quote
specialblend07 Posted November 19, 2018 Report Posted November 19, 2018 I have pictures of DMs with custom heads and also ported water jackets. I looked into this, and also cooling changes before i sold my most recent DM cylinders. I talked to a LOT of builders on here and not. The RZ street bike/aprilla guys have been doing this shit for years with the DM/SS cylinders. If you go on those forums you'll find a fuck ton more information then here on it. Below is a forum that has information on cooling of banshee based cylinders, just used in a motorcycle chassis. These guys have a TON of information on this shit. My profile wont let me search far enough back to my post on cooling a DM. I THINK I had some links/photos there (EDIT thread is deleted). https://www.apriliaforum.com/forums/showthread.php?246083-TSS-RS500GP-(round-3)-cylinder-problems/page23 Quote
