hoppedupandcutdown Posted August 19, 2017 Report Posted August 19, 2017 1 hour ago, rjdgriff said: God damn, dennis, you made me look like a dick!!! You is a righteous dude mr. Elliot Giving away "TSS" for FREE!!! Ah, you know, the nursing school thing hits close to home for me. 1 Quote
rjdgriff Posted August 19, 2017 Report Posted August 19, 2017 Ah, you know, the nursing school thing hits close to home for me.This is very true! Missed you last night at the races! Was hoping you would be thereGiving away "TSS" for FREE!!! Quote
hoppedupandcutdown Posted August 19, 2017 Report Posted August 19, 2017 1 minute ago, hoppedupandcutdown said: Ah, you know, the nursing school thing hits close to home for me. It's no secret, Christine is my favorite. 1 Quote
hotrod9193 Posted August 20, 2017 Report Posted August 20, 2017 The sheebitch is starting to worrie me, after doing some riding today she started smoking from the right tail pipe "standing at the back of the bike" way more than the left and at idle even, seems to me like coolant issue, what might cause this? I know there's other places to post this but everyone's more active here than anywhere else Sent from my SM-G930R4 using Tapatalk Quote
hotrod9193 Posted August 20, 2017 Report Posted August 20, 2017 Sorry it's not a coolant issue seems to be a carb issue, need to have the carbs synced. Anyone near seminole ok got the tools to help me out on this?Sent from my SM-G930R4 using Tapatalk Quote
rjdgriff Posted August 20, 2017 Report Posted August 20, 2017 Sorry it's not a coolant issue seems to be a carb issue, need to have the carbs synced. Anyone near seminole ok got the tools to help me out on this?Sent from my SM-G930R4 using TapatalkYou can get it very close without the sync tool. Take off your air filters (and air box if you have one) so you can see the slides. When you push the throttle (bike shut off) do the carbs start and stop moving at the same time? Push slow and steady. If they do not, adjust at the caps until they move as close to perfect as you can see Giving away "TSS" for FREE!!! Quote
spurdy Posted August 20, 2017 Report Posted August 20, 2017 You can get it very close without the sync tool. Take off your air filters (and air box if you have one) so you can see the slides. When you push the throttle (bike shut off) do the carbs start and stop moving at the same time? Push slow and steady. If they do not, adjust at the caps until they move as close to perfect as you can see Giving away "TSS" for FREE!!!I think Ryan's advice may be misinterpreted. The slides typically have no choice but to move at the same time since the are controlled by a single cable. What is important is that the position of the slide in the carb is identical. The slide raises and creates an opening for air to be drawn through. This open needs to be identical. The lever the opening, the more air flow allowed. The sync tool measures this air flow and allows you to get them set the same. You can also do this by eye but it isn't as accurate. Make sure as you begin to open the carbs, both slides come off the bottom position at the same time. Too much slack on one side can allow that carb to rest in the bottom position while the other slide begins to raise. Then make sure their heights are equal as they move up. Equal in one position means they will be equal in all positions, aside from the resting position. Sent from my iPhone using Tapatalk Quote
rjdgriff Posted August 20, 2017 Report Posted August 20, 2017 I think Ryan's advice may be misinterpreted. The slides typically have no choice but to move at the same time since the are controlled by a single cable. What is important is that the position of the slide in the carb is identical. The slide raises and creates an opening for air to be drawn through. This open needs to be identical. The lever the opening, the more air flow allowed. The sync tool measures this air flow and allows you to get them set the same. You can also do this by eye but it isn't as accurate. Make sure as you begin to open the carbs, both slides come off the bottom position at the same time. Too much slack on one side can allow that carb to rest in the bottom position while the other slide begins to raise. Then make sure their heights are equal as they move up. Equal in one position means they will be equal in all positions, aside from the resting position. Sent from my iPhone using TapatalkAnd this is why I am not a teacher Giving away "TSS" for FREE!!! Quote
Burke Posted August 20, 2017 Report Posted August 20, 2017 1 hour ago, rjdgriff said: And this is why I am not a teacher Giving away "TSS" for FREE!!! I understood perfectly 1 Quote
rjdgriff Posted August 20, 2017 Report Posted August 20, 2017 I understood perfectlySpurdy is paid to over analyze and over think everything. Stupid safety people Giving away "TSS" for FREE!!! Quote
spurdy Posted August 20, 2017 Report Posted August 20, 2017 Spurdy is paid to over analyze and over think everything. Stupid safety people Giving away "TSS" for FREE!!!How did I get brought into this? Lol!Sent from my iPhone using Tapatalk Quote
rjdgriff Posted August 20, 2017 Report Posted August 20, 2017 How did I get brought into this? Lol!Sent from my iPhone using TapatalkYou brought yourself into it? Are you already drinking without me? I am on my wayGiving away "TSS" for FREE!!! Quote
Burke Posted August 20, 2017 Report Posted August 20, 2017 To be fair... People for the most part, are really fucking dumb. And I'm not calling anyone out, so don't go all Antifa on me. 3 Quote
ClaudeMachining Posted August 20, 2017 Report Posted August 20, 2017 11 minutes ago, DDQ said: What is Antifa? The dumbest counter part of far right. Quote
hotrod9193 Posted August 20, 2017 Report Posted August 20, 2017 Gonna take my carb issues into the proper area, please check it out Sent from my SM-G930R4 using Tapatalk 1 Quote
