I have a 1989 bansee. She ran GREAT until recently. A few weeks ago while at the dunes it seemed like the power delivery was off. It sounded like wah wah wah wah not us usual (If that makes sense) Later that day I parked it and it would only turn over then die as soon as I went to 2nd or pressed to much on the throttle.
So i replace the top end (had some piston slap)  that didnt fix it, replaced the electrical (except CDI) and nothing. replaced flywheel and stater. It will almost fire but wont run :(
does this sound like the CDI is out? Or something I missed?
First we're gonna need pics of you wearing little to nothing. Secondly, how do you know it had piston slap? Did you measure the bores? Did you have it bored? Stock carbs? If so is the choke tube on?
Sent from my SCH-I545 using Tapatalk
  • Like 1
Top end is oem. Reeds are good. Tors and parking break removed.
Compression good.
Have not checked carbs but I'm going to when I get home and borrow a cdi from a friend :)
