nothing really done to it. top and bottom has been rebuilt. everything is pretty much new except for CDI box and reeds. Im wondering if its sucking in air somewhere on the right side because thats the only side having an issue.
It ran like a champ then one day it just didnt. it will idle but as soon as you gas it it loses power and dies out. now its backfiring on the right side. Reeds looked fine but maybe theyre not. Im just so sick of replacing things and its not the issue lol
You can set your timing at +4 but that's not your issue. If you think there is an air leak, I'd test that before you buy a new cdi. They aren't cheap.
Take apart the choke circuit? Check the tube between the carbs. Slides are the correct direction with the cutaway facing the rear?
went to +4. I just checked and the tube was gone that connects the two. put one in and no more back fire!! Both pipes have exhaust coming out. Still sounds rough tho. Still wanting to die out :(
Its running 100% now woooo!! changed the plug wires, changed timing from 0 to +4, and putting that tube back on the carbs did it (not to mention the total rebuild) Just ran for 15 min no problems. Taking her out this weekend to the dunes well see if shes back to life.
Edited by Banshee_Babe
