Banshee_Babe
    3
Everything posted by Banshee_Babe
  1. Can anyone recommend a good site to buy one of these? Ive heard the ones on ebay fall apart easily. Thanks!
  2. Still alive! Been ripping out at the dunes, the 'Shee has been running amazingly after replacing the stater and jetting it.
  3. I'll take a few good pics this weekend let ya know how she runs!
  4. Its running 100% now woooo!! changed the plug wires, changed timing from 0 to +4, and putting that tube back on the carbs did it (not to mention the total rebuild) Just ran for 15 min no problems. Taking her out this weekend to the dunes well see if shes back to life.
  5. went to +4. I just checked and the tube was gone that connects the two. put one in and no more back fire!! Both pipes have exhaust coming out. Still sounds rough tho. Still wanting to die out
  6. nothing really done to it. top and bottom has been rebuilt. everything is pretty much new except for CDI box and reeds. Im wondering if its sucking in air somewhere on the right side because thats the only side having an issue. It ran like a champ then one day it just didnt. it will idle but as soon as you gas it it loses power and dies out. now its backfiring on the right side. Reeds looked fine but maybe theyre not. Im just so sick of replacing things and its not the issue lol
  7. The CDI I was going to borrow didnt fit Also the timing is a 0, what should it be at for stock bore?
  8. So I cleaned my carbs and got it to start. Runs rough in idle. backfiring out of the right side only. Changed plugs and wires. Still doing it. you can see the exhaust coming our of left side and almost none on right. Any ideas?
  9. Top end is oem. Reeds are good. Tors and parking break removed. Compression good. Have not checked carbs but I'm going to when I get home and borrow a cdi from a friend
  10. I have a 1989 bansee. She ran GREAT until recently. A few weeks ago while at the dunes it seemed like the power delivery was off. It sounded like wah wah wah wah not us usual (If that makes sense) Later that day I parked it and it would only turn over then die as soon as I went to 2nd or pressed to much on the throttle. So i replace the top end (had some piston slap) that didnt fix it, replaced the electrical (except CDI) and nothing. replaced flywheel and stater. It will almost fire but wont run does this sound like the CDI is out? Or something I missed?
