Serval build
Ok
I know it was yours the yellow one on the beach
It was the bike that made me decide to get mine doni liked the numbers
I'm not a top end pipe hater I'll get one in the fullness of time
I'm just seeing what I can do with slp first
I know 95 percent of you run top pipes cause your hill shooters , duners ,drag racers running oofs and inframe short length pipes
I understand that
I'm just saying if your runnin 90 plus horse and 4 inch swinger ,given the same rider on a 87 horse with standard lenght. Swinger in tight bush tracks or tracks with pea gravel which has no traction the 97 hp bike will find it harder going cause power won't matter but the longer swinger will be harder to ride generally it's set up for application you all know that!
So all I was doing was experimenting with my serval
I love power
Used to drag race on asphalt my 500 mx two wheeler hell I even had hand coned pipe made for it 20 plus years ago
Rode trials before that
Point is you guys run hot bike with hot number
I know enough to get in trouble got the trophies on the cabinet
Is your bike faster than mine yes are you a better rider who knows
Al I know is when I finished wrenching my wife's rappy 2 off my sons banshees then I can put my serval together , the. Get my daughters rappy her boyfreind rappy and my granddaughters little quad and just ride
Got ya. I spend about 15 minutes a weekend dragging. I'll probably do another serval with slp's if I can ever get this 250r geo mx build going. For a duner, those pipes would sign off way too early for my liking.
I scratch out the jugs and there's a new dyno at this place who specialises in drag banshees but dose all performance quads he was doing a 4 wheel farm type quad with racks and all auto as well putting down 100 hp kept throwing belt but guy wanted a real sleeper
Put my pistons and 2 sets of domes that can gave me to try in to get ceramic coated and moly coat that'll get done before assembly
I was running 20 cc plus 30 thou shaved with 34 thou squish on stock mx port running 180 psi plus on our 98 pump gas with the ceramic set up no deto detected so I figure I'll do the same to serval maybe not so high
My sons serval didn't like much comp just held the revs back
OP, please make an effort to try to post with better grammar. If English is not your first language, then i understand you cant. If it is, you are doing it on purpose. Stop using slang if you know how to speak/type.
Now back on topic. All i keep seeing is rwhp numbers posted by you. You need to focus on power delivery. Adding 5-10 hp of peak power might kill power else where where you want it. Talk to a good builder and tell him what are your goals and what he can do help meet your goals.
I personally dont understand nor ride enough bikes to understand how curve curves feel on any said pipe. So i had to talk to a builder and tell him what i wanted. That and with guidance from these forums, ill sure ill be happy once i finish my build.
If those measurements are legit, you have issues in your future.
Yes why had the crank welded
You recon the bearing will quit
Anyway it dosnt matter now
I'm doing this new motor I'll go with the domes can gave me I told him I run high comp
So he gave me 24cc what he recommends and a set off 23cc both off which are getting coated(ceramic);
And as for the flamers you could feel em wanting to jump on the hate train you all need each other to feed egos
Ha ha
