96SilverlakeShee Posted October 13, 2008 Report Posted October 13, 2008 well i have owned a banshee for the greater portion this year and loved every second of it. Recently a bad throttle cable (aftermarket tors removed) caused some dirt entry into my motor and killed my pistons. The banshee has had much work b4 and after this rebuild. b4 includes shaved head fmf gnarleys K&N with lid removed trail port FMF jet kit hot rods stock stroke crank bored .80 over 2 degree advance timing key needless to say the head was damaged enough to have to have it milled to the point of losing some compression. The stock cylinder walls i didnt want to take a chance on damaging them either. And the reeds were cracked and badly needed to be replaced. so here is the list of other mods in addition to i have added. Prodesign cool head Vforce3 reed intake system LA sleeve big bore sleeves and pistons 68mm new tors eliminator kit with carb caps So i slapped it together and i cant get it to start for the life of me. Today i disassembled the top end and re assembled it to make sure torque specs of 20 lbs were god and there was a lot of compression in the new top end evan kicking it over ( I ripped a hole in my shoes from backkicks). The motor itself doesnt start unless i give it some gas and evan then it backfires and seems starved of fuel. It would not run for more than 30 seconds and evan then it sounded horrible and bogged way out evan with throttle wide open. I thought the fmf jet kit would suffise enough to get it running b4 i had to jet it but im pretty sure thats why i cant get it started w/o giving it fuel. During the rebuild i cleaned the carbs several times. The float bowls needed to be replaced when i got the bike but i dont see how that would make it not start since its just dumping some extra fuel onto the ground. Personally I am not a carb man and havent done much jetting but im pretty sure this is the direction i need to go but am open to any suggestions. my height elevation is at sea level and i run 93 octane with supatechnaplate oil from klotz at 40:1. This banshee has always run 40:1. This year when i tried to run 32:1 in it it would not evan start. But that was b4 the rebuild. OMG its almost november and I need to 2 stroke it bad Quote
gmctruck1976 Posted October 13, 2008 Report Posted October 13, 2008 Have you checked to ensure the carbs are in sync. Quote
98_banshee_newbie Posted October 13, 2008 Report Posted October 13, 2008 KI would mess around withyour jets and needles Quote
96SilverlakeShee Posted October 13, 2008 Author Report Posted October 13, 2008 More info--- Yes i did the carb sync right after installing the new tors eliminator kit. The slides drop low enough to here them lay onto of the carbs as well. gotta luv that clunk noise they make when they drop down. Also i am running 22cc domes on the pro design head. Quote
biggun6ss Posted October 13, 2008 Report Posted October 13, 2008 What size jets are currently in the bike? Are you running stock carbs, and if so is the choke tube connected? Have you checked to see if you are getting good fire at your plugs? Is the timing correct? Quote
96SilverlakeShee Posted October 13, 2008 Author Report Posted October 13, 2008 not sure on the jet size but it was fmf jet kit for the gnarleys so i assume its pro like 270 or close. as for the crossover tube it is installed and replaced with this build. As for needle settings its on the 2cd from the top so its set lean but this bike ran perrrrrrrrrfect b4 this all happened i mean no backfires/kicks over 1st start every time/ timing was great (2 degrees advanced). Now that i can't get it to start i cant really check the timing ya know... Quote
r_flagel222 Posted October 14, 2008 Report Posted October 14, 2008 (edited) check to see if the choke {cross-over hose} is there in place...... i just had a banshee of my buddys kick my ass for 4 hours till i saw the rubber tube that runs between the two carbs and connects them was removed.... i had the same sympoms as you are desribing.... good luck you may have or may have not been talking about this tube in your last reply......... i gota make sure.... some say crossover tube and mean the one on the intakes..... good luck once again Edited October 14, 2008 by r_flagel222 Quote
akita8 Posted October 14, 2008 Report Posted October 14, 2008 Check your flywheel to see if its spun on the shaft. Quote
bbcmudtruck Posted October 14, 2008 Report Posted October 14, 2008 Make sure the slides are in the right carbs. Quote
magz Posted October 14, 2008 Report Posted October 14, 2008 check the flywheel timing gap. .018-.020 anything more then that and you get weak spark or no spark, the 4 things you need to run good. air - check to see nothing obstructing airways into the motor fuel - check carbs to see if they have fuel by draining some out the bottom psi - do a compression check to see if you have a minimum of 100 psi spark - have a buddy kick it over and see if your getting spark. if you got those 4 things it should be running, check timing gap if no spark or make sure all your wires are connected right and not all rusted up. use fresh spark plugs. Quote
randal92 Posted October 14, 2008 Report Posted October 14, 2008 Did you remove the TORS after the rebuild? and did you splice the two wires that go to the throttle switch? Quote
sinisterboo Posted October 14, 2008 Report Posted October 14, 2008 Check your flywheel to see if its spun on the shaft. Im with this guy, check that timing key. And not to sound like a smartass, but are the pistons in correctly? LOL I have had 4 bikes brought to me this summer for no-starts, only to find their "do it yourself" top end job was done wrong....... Quote
magz Posted October 14, 2008 Report Posted October 14, 2008 Check your flywheel to see if its spun on the shaft. Im with this guy, check that timing key. And not to sound like a smartass, but are the pistons in correctly? LOL I have had 4 bikes brought to me this summer for no-starts, only to find their "do it yourself" top end job was done wrong....... ha!, when i got my juggs back from passions he said he'd see that all the time people putting the pistons on backwards... Quote
sinisterboo Posted October 14, 2008 Report Posted October 14, 2008 Speaking of rebuilds, hows your new setup run magz? mine goes quite well, if I may say..... LOL Quote
96SilverlakeShee Posted October 14, 2008 Author Report Posted October 14, 2008 the crossover tube is in place yes. To those of you who think im a nub and cant put the arrows on the pistons facing the correct way you make me a sad panda. I havent checked the flywheel at all i was hoping to not get into the left side of the motor :geek:. Pretty much thinking i have some week spark so flywheel is probably going to get looked at. but from the information i have supplied could someone say that the jets should make the banshee run ? I was thinking that it should run and i would just re-jet it after i got it running. As for the TORS removel it was done b4 the rebuild but the throttle cable let dirt into the motor so it had to be replaced so i purchased the kit with new carb tops. Quote
