biggun6ss
Contact Methods
  • Website URL
    http://
  • ICQ
    Borger, Texas
    2005 Blue Banshee, Toomey T6
Recent Profile Visitors
1,405 profile views
biggun6ss's Achievements
HQ Soldier
HQ Soldier (2/5)
  1. The intake is a BOSS. I measured the bolt holes to be 2 3/8 apart center to center. Does this sound about right?
  2. I currently have the billit intakes but the rubber section that connects to the carb is starting to crack. Is there anyone that sells just that piece or do you have to buy the whole billit piece?
  3. I have a 2005 with 4mil longrod dune drag port. Currently I am running 8 paddle haulers but i seem to be spinning bad when i take off. Would a ten paddle help with the takeoff but not kill my top end? I am also using stock gearing, if I do go to the 10 paddle, should I change my gearing at all? Also with my setup, what cc is my motor (stock cylinders)? The reason i ask is because my friend has a yfz 450 with intake and high compression piston. I raced him a couple weeks ago but he stood no chance (he is new to riding so that was a major factor). Now he is getting cams and his head ported, I still don't think he will touch me, my passion motor runs too good, but i want to make sure I get out of the hole effeciantly.
  4. Haven't been to the site in a long time, was reading through the post and saw alot fo talk about serval motors. What the hell is a serval motor?
  5. Call your builder and get a full drag port and get some bigger carbs with some good filters.
  6. What size jets are currently in the bike? Are you running stock carbs, and if so is the choke tube connected? Have you checked to see if you are getting good fire at your plugs? Is the timing correct?
  7. I pulled the boot up so you can see what i am talking about. The end of that L adjuster that slides into the brass likes to come up when given throttle.
  8. Yes I have those rubber boots but they do not fit very sung.
  9. Maybe I can explain this better. My throttle cable connects to the thumb throttle assembly just fine. Its the other end that gives me problems. The cable runs from the thumb throttle then splits into two seperate cables, one for each carb. At the end of each cable there is an L shaped adjuster which is threaded on both ends. I used one end of the L for adjustment. The other end of the L sits inside the carb top adjuster but when I give the bike full throttle it wants to pull up out of the carb top adjuster. I haven't got to start the bike yet still waiting on a few parts. Everything is adjusted, the slides open fine. I am not having problems getting the cable into the slide its the adjuster around the cable that is moving causing the cable to open the slide. My worry is that if that L shaped adjuster moves too far up it may hold the slide open.
  10. So no one has problems with the cable coming out of the brass. Seems to me if the cable moved to far it might hang wide open.
  11. I am now using 35's due to a new port job done by passion. I have a new throttle cable but I am having problems where the throttle cable runs into the carb. At the end of the cable there is a L shaped tube threaded on both ends and the carb top comes with a brass tube which is threaded on one end and smooth on the other. Should I unscrew the brass adjuster out of the carb top and use the L or let one half of the L sit inside the brass? Only reason I ask is because with the L inside the brass, when I push the throttle the L wants to lift up. Is there a good way to keep the L in place?
  12. Just had a 4 mill with a dune/drag port done on the banshee. Using 35 PWK so I have no need for the tors anymore. Have the bike torn down to nothing but frame and wirring harness. What all needs to be removed to get rid off all the tors junk. Is the little button inside the thumb throttle part of the tors and can that be unplugged?
  13. That could be your problem. Try syncing your carbs and find out.
  14. I would go with some 300's and see how it feels. I suggest sredish post because it tells you everything you need to know. You already have your baseline jetting so moving from there isn't hard. Unless its a massive temp change you won't go very far from your baseline jetting.
