t-5, filter, soon timing plate, and heavy ass 22 inch 6ply gators, do i need all 6 stiff springs that i put in or can i use just 3 soft 3 stiff or all soft if possible?
Run heavy duty and use an ezpull perch, clutch will last longer and feel as if u have the light duties. light duties just dont seem to last, keep in mind its a spring, it sits there halfway compressed it WILL wear out quick, even quicker with a light duty resulting in premature slippage. my .02
okay guys thanks, i do have an easy pull and new cable on the bike, but with the big tires (i mean real heavy) i usually need to use my clutch alot, ill go with the easy pull ones till my clutch goes, then i will use 50/50
I've got Jeff from FAST's EZ Pull perch, the lever has a ball bearing pivot, not just a sleeve.
With that lever, bearing and a new cable, I have 6 HD springs in mine and it still pulls like a 125cc new dirt bike....
a good ez pull makes a night and day difference no doubt, we have used them on everything from the old school cr 250 to kx500's,zilla's to shee's, wont roll without one :thumbsup:
im a strong kid, all my buddies cant stay on my shee for more then 10, the thumb throttle and clutch is too stiff, and after 7 hours for me it gets hard. so should i go with stock springs or 50/50 im not sure, ill probably buy the clutch lever from fast and i have stock gearing too. i do have a 13 tooth front but then i can't tighten the chain enough to specs, so maybe ill buy a rear sprocket with a few more teeth on it. i ride fast in the trials, especially with only having stock susp. etc, but i know for a fact that i wll be able to ride much harder and safer with easier thumb and clutch usage.
thanks for input guys
web link??
