rzcolobanshee
Everything posted by rzcolobanshee
  1. Wow I used to get fakes all the time based on that....I get them at checker now and they are the real deal
  2. i don't, my cousin may...you would have to come to berthoud, pm him here, his screen name is ScrewMachine
  3. So what's the dealio 1BAD? are they mine?
  4. If it's not locos friend, then it's me! I haven't heard anything though......
  5. I assume if they came from tom they are the old style silencers? And I got first dibs on these
  6. Thankfully Walter was helpful, I've got it now
  7. Someone has to hook me up here, I could potentially get laid lol....I'm very limited to how I can get it or I would allready have it. I can only get it through someone elses ftp or if you use www.yousendit.com which is very easy to use. Thanks guys
  8. rebel is correct, the small bores hold in the exhaust for too long and will cause overheating, thats why you were getting hot so fast, plus your choking your top end, sell those puppies and get some shearers
  9. I'd be interested in the carbs if MC420 doesn't take em
  10. I found some chrome cpi's for $350 so you can have them superchicken
  11. May want to check to see if the thermostat is opening (i completely removed mine)
  12. Mains seem really really small, I'm running 290's at 5000ft elevation and 26mm carbs, I would guess you need to be around 340 or so
  13. I may go that weekend, might depend if I have any drag pipes by then
  14. 12v I believe led's need some special resistor though, I believe Justintoxicated knows about that shit
  15. I'm almost positive you can, as long as there is a little screw on the cover and a tab on the shift drum that touches it while in neutral, then hook up any little light with a hot wire going to it and the ground going to that screw on the shift drum cover, then the light is only grounded while in neutral...make sense?
  16. Do they have a coating or just painted?
  17. Got pics?
  18. Looking for either CPI, Shearer or GRR Small Bore Drag pipes
  19. Big bore pipes might help a smidge
  20. If you have to ask what a helix bore spacer is you don't need to know john. You are clearly not 'in the know' Notice the custom swingarm? That shock must be hating life
  21. Don't forget the knuckles on the front.....Hang on if this is for your girlfriend do the bare minimum unless she's paying for everything, most likely you won't be with her in a year from now anyway. Spend more time fixing up your bike
  22. Drum is no different fyi and it's not really a bearing, the pin is just seperate from the fork and rolls inside the fork rather than being solid
  23. If you have a servo motor I'll buy it Not without the drive gears (pretty much need the top half of the case)
  24. Your caliper is fooked, time to get a new one or put on a 250r caliper
