locogato11283
Admin
Everything posted by locogato11283
  1. 87sheerips fo sho. im locogato11283, and i approve this message.
  2. hahahahahahaha.. who you gonna report me to??
  3. the axle works great.. im not sure about those hubs.. anything thats called micro lite, i would probably stay away from for jumping.
  4. i would start with 160 main and 48 pilot and work from there.
  5. pull the bottom off and see if the float is hanging up. if so, fix it.
  6. this problem started only when you changed reeds and jetting?
  7. you should ditch that single carb setup. theres more power to be had with 2 carbs.
  8. ok that post is a mess.. for simplicity, just tell us exactly what youre running now. jetting specs, carbs, pipes, reeds, air filter, porting, temp and altitude. also wanna know what fuel/oil mixture.
  9. i would maybe double check with another tester before you tear into it. if they are truly off that much, then you need to figure out why. how old is the topend?
  10. yep, careful with a razor blade and then maybe some parts cleaner. make sure you use an air hose to blow all the little shit out.
  11. i used a couple long springs.. from a dirtbike i think. dude, dont let the plug and petcock thing get you down. those pipes are good pipes. youll be happy with them.
  12. time for a roundhouse carrier swingarm.
  13. just cheap ass 10w-40 motor oil for the tranny and klotz at 50;1 for the cylinders.
  14. i would say no more than 5 pounds a piece..
  15. you do realize that with better parts it will make it harder to shift on the move. thats why a lot of people are going to duneable overrides.
  16. its gonna depend on what tires you have and what youre racing on. also, what gear are you launching in?
  17. i agree.. putting the motor into the trike frame would be best.
  18. i want it.
  19. dale, give it a shot man. i would never go back to explorer. the firefox just seems to work so much better. you can also set it up just how you like it. im not sure if the newer explorers have the kinda options firefox has or not. i havent used explorer in 5 years prolly.
  20. word... dr. q will just send it there anyway.
  21. no way hes serious.. is it april 1st??
  22. its hard to beat a good set of elkas.
  23. you seen that????? come on cody!! you saw that!!
