themudgician
themudgician's Achievements
  1. fmf pipes, boyen rad valves, 28 pwk carbs, +4 timing, cool head 19cc, .060 over. thats about all the mods i can think of.thanks
  2. i will order a new one, thanks. i hope it fixes my problem
  3. ive been having problems with shifting at wot. i put a new shifter shaft modded from fast with modded star, and lighter spring.it shifts fine just riding around or if i shift it as soon as it gets in the powerband, but if i let it rev up to high it wont go in the next gear. i tore it down it has a billet basket, but the clutch hub has a bunch of grooves wore in it. thats all i see thats not right. could that cause this problem by not letting the cluch realase like it should. any help would be greatly appriciated
  4. i just put a ground star and fast modded shifter shaft,and lighter spring a couple weeks ago and it cured it for a while, now its doing it again wont shift at wot but shifts perfect just cruising around. i think it has stock clutch springs.
  5. wacko did u ever figure out the problem mine just started doing the same thing
  6. COOL THANKS GUYS THAT MAKES MY DAY. I AM A LITTLE INTIMIDATED SPLITING THE CASES PLUS I RIDE EVERY DAY AND DONT WANT TO BE DOWN THAT LONG. THANKS 4 THE GOOD NEWS
  7. THAT SUCKS I WASNT WANTING TO GET INTO ALL THAT. MAYBE I WILL TRY A THICKER OIL THAN ATF FLUID.
  8. MY COUNTER SHAFT SEAL BEHIND THE FRONT SPROKET IS LEAKING. WHAT IS THE EASIEST WAY TO CHANGE IT. ANY HELP WOULD BE GREATLY APPRICIATED.
  9. i replaced the shift shaft, shift star and eliptical bolt and it shifts perfect now. the shift shaft was worn out
  10. i am new to banshees, is it normal 4 banshees to have a vibration off idle. i dont notice it at idle but when i rev it up i can feel it in the handle bars and foot pegs. i just replaced the clutch basket bushings, is there anyway i could of put somethin togather off balance in the clutch
  11. cool let me know
  12. IM NO PRO BUT I WOULD THINK U WOULD WANT RINGS FOR THE BLASTER PISTONS 4 THE BORE SIZE OF YOUR JUGS. MAKE SURE YOU CHECK YOUR RING GAPS TOO.
  13. did you run the numbers on the carb, how old is it, is it a reliable setup. are you currently running it.my air box also has a pro flow kit in it.what reeds are you running i got boysen rad valves and they have a notch in the top around the boost bottle area i dont know if they will work with ur setup. if we traded maybe we could meet in shipshewanna. let me know for sure what carb is. i just got my setup runnin good.half scared to take it off now
  14. i centered it jacked back tires up and spun tires and shifted it, some times it wouldnt upshift all the way or down shift. i took shift shaft out and repeated but shifted by hand and it went in every time.
