Gemeiner
Everything posted by Gemeiner
  1. Hell ya, thanks dude. Wanted to make sure before I slap it all together. Sent from my SM-S928U using Tapatalk
  2. Guess the answer is yes they need em and they didn't come with em. Good to know. Sent from my SM-S928U using Tapatalk
  3. Just grease, put in the pivot pins and slap it in there? Sent from my SM-S928U using Tapatalk
  4. Got a roll design long travel a arm kit and im not seeing any dust caps for the joints like the stock ones have. Is that normal? Sent from my SM-S928U using Tapatalk
  5. you ever seen a nice looking banshee in stock silver? No you haven't. Pick a color, trick it out a little. I sure as hell wouldn't PAY someone to make it look stock lol. Sent from my SM-G975U using Tapatalk
  6. Dude i need to do that Sent from my SM-N920V using Tapatalk
  7. Put it this way. I know dudes living in mexico in big ass houses living rich making 9.50 an hour. Ive met illegals that made 75 bucks a week in mexico and that was considered a lot. Try to compete with that when the average apprentice starts at 17. Sent from my SM-N920V using Tapatalk
  8. You act like construction is difficult to learn. Plumbing roofing electrical masonry all of them are being taken over. Tjey start as laborers and work their way up with experience while making half as much as you. Their companies can bid low because of the money they save and legit companies paying american workers cant compete with bids that low. Sent from my SM-N920V using Tapatalk
  9. Ill do that. thats exactly what i was wondering about. I think im still lean on my 55 pilot. FAST says i should be at 58. Plus when i was riding earlier it ran pretty decent at 60 degrees but once it cooled off this afternoon like 40 degrees it started running like crap on the bottom. Its pretty much broken in now so ill do a plug chop and see whats going on. Sent from my SM-N920V using Tapatalk
  10. I started with 58 pilots but it smoked a lot so I went to 52. but bottom end was bad with a 52 pilot and turning the air screws in made it better so I went to 55s. going to 55s made a huge difference, it starts first kick and feels good but I noticed a flat spot in 4th. haven't adjusted the main yet
  11. So i should go down a few sizes on the main? Sent from my SM-N920V using Tapatalk
  12. Wire harness touched the pipe and melted. Easy fix. Just in a bad spot since i removed the airbox. Need to figure out where to put it or if i can insulate it. Sent from my SM-N920V using Tapatalk
  13. It just died on me yesterday. Ended up pushing it a few miles. No spark for some reason even with new plugs. Sent from my SM-N920V using Tapatalk
  14. Walkin now lol died on me. Not sure why, it seemed good then bam just stopped. One plug was oily tho. Sent from my SM-N920V using Tapatalk
  15. Dont forget im at 4000 feet so i should be smaller than yours. Im only noticing trouble on the bottom end right now. It was sluggish on the bottom with the 58 pilot amd smoking so i thought it was rich so went 2 sizes down to 52 which ended up too lean. Gunna try 55s now. Mid and top pull so hard its awesome. Just gotta dial in the pilot Sent from my SM-N920V using Tapatalk
  16. New plug fixed that. Mustve started way too rich. Starts first kick but its still rich. Gunna mess with my idle screws Sent from my SM-N920V using Tapatalk
  17. Just got my new 421 serval motor in the frame and im trying to break it in but im having some problems. Its a 421 dune/play ported serval. I have pc pipes for now, 35mm pwks, k&n filters with outerwears, vforce 4 reeds, With 35mm pwks i Started with 155main and 58 pilots with the needle on the 4th clip, im at 4000 feet. I synced the carbs and when i started it, It seemed rich and wouldnt idle. So i went down to 52 pilots which helped the smoking and it idles when its warm but not when cold. Also the right cylinder smokes and pops a little. It has a chariot racing cool head so i know the o rings could be off. Not sure if compression testing would tell me much since i havent broken it in yet. Also when I was syncing the carbs i noticed a little smoke came out of the carb on the right side Sent from my SM-N920V using Tapatalk
  18. Nevermind i found it. Got lucky Sent from my SM-N920V using Tapatalk
  19. Hey guys i was in a rush last night and one of the plastic slide collars that hold the throttle cable in place flew off in my garage. If i dont find it has anyone used something else temporarily? Or am i screwed. Just got my motor back after 3 months at the shop so im pretty done waiting. Sent from my SM-N920V using Tapatalk
  20. I got a couple gallons of amsoil dominator. Thats what ive been running. Sent from my SM-N920V using Tapatalk
  21. Sounds like it could be rich to me not sure why itd happen all of a sudden though. Sent from my SM-N920V using Tapatalk
  22. Ya thatd definitely discolor it atleast. Not sure what else itd do Sent from my SM-N920V using Tapatalk
  23. Hahahahaa oh shit Sent from my SM-N920V using Tapatalk
  24. 4 mill means longer stroke which equals more bottom end and over all power. Porting makes the motor. No spacer plates. Whether you go 4 mill or not, should probably go long rod to reduce side load and help reliability. Sent from my SM-N920V using Tapatalk
  25. Picked up Zillas 35mm pwks for a great price. From the chart theyre pretty close to the 33s on the bottom but with more up top. As long as that front end pulls up ill be happy lol. Been waiting on my motor to get back for like 3 months though. Just wanna ride. Sent from my SM-N920V using Tapatalk
