hondaracing02
    2003 Banshee
hondaracing02's Achievements
  1. awesme! thanks for the help! thing rippsss ha
  2. its not blwoing out radiator cap though, only overflow. so shouldnt be headgasket. has never done it since after hours of riding it. pretty sure it was just adjusting coolant level. thanks!
  3. i had one carb top in backwards, so it was wide open thanks!! it does blow coolant out overflow tube when ive been riding it then let it idle though, whats that from? too much coolant since i just filled it?
  4. i split it completely in two, just didnt take off idler gear and other things that didnt need removed. all new crank seals
  5. yes, i put yamabond everywhere, i said that already
  6. okay! ill give that a shot. is there a certain way i should route the cable? i just ran it in open space really.. i do have a clymer, I could check that haha. I did pull both caps and had a buddy twist the throttle and they moved seemed to move up and down correctly? so not sure why they wouldnt in the carbs when the caps are back on, but could be!
  7. the throttle cable did come out of one carb, i just pushed it back in? and good idea on the filter pulling. I did use a rough pad on a drill and spun all over the cases to clean old stuff off. then applied thick yamabond everywhere
  8. it still has a ton of power? how would air get above the piston? i never removed anything in topend
  9. but the cases are below the pistons? why would it rev so high? and i put yamaha \bond everywhere. thick
  10. I managed to weld the ball and push rod together, so I pulled the motor and split the cases. (first time doing this so may have done something wrong.) I basically only removed what I had to, and slightly lifted tranny to put new push rod in. then did the pancake bearing update. I did lift the crank from the bottom some because i had to put the new crank seal on. then i put it back together with yamabond. The stator i didnt know if it had to be lined up or somethin like a 4stroke timing, so i just put the flywheel on the key and bolted flywheel on, toqued down etc. carbs sat for probably 8 months on there sides on the ground, in a non dusty spot. put them in and didnt know what needle went with what carb so tried both. both times the quad runs full throttle as soon as youstart. i dont think i have a t.o.r.s, previous owner must have removed that, and the needle/throttle cable appear to be working right, i checked both of them, they slide right. i do have alot of open connections under fuel tank, not sure what thats about. any ideas?? cant figure this out, and when i say full throttle, i mean its damn near gonna blow and the twist lever is resting all the way forward... thanks
  11. no. i wanted to see if anyone had an idea to get the rod out
  12. i got the actuator out.. and the head of that side of the push rod is smashed up like the head of a nail.
  13. hit the push rod with a punch and its not froze! exciting right! the flywheel side is bugged up tho...so it wont slide out.. lol. any new ideas? or back to splitting the cases..?
