Zillaguy
    2
Everything posted by Zillaguy
  1. Im on pump fuel at +7°
  2. Ubly Dragyway in Ubly, Mi. Is quad friendly.
  3. The adapters came with a sheet, that has a formula to get the correct torque.. it involves measuring the torque wrench center to center, and the adapter center to center.. then you plug those two measurements into the formula, and do the math.. im pretty sure with my torque wrench and the adapter, 22ft/lbs is 17ft/bs, but i always convert to Nm (Newton Meters).. because it's more accurate
  4. I use Matco torque adapters. I have a set from 10-19mm.. i think it was $85. As far as torque wrench i have 1/4, 3/8, and 1/2, Snap On digi's with torque angle.
  5. Discoloring is NOT normal. If the bike is tuned properly, the pipes will not discolor. I run show chromed Rockets, and they have never discolored.
  6. Wha choo kno bout da Cass Corridor foo? Ha i was just over that way the ther day. I hate going downtown more everytime i go there!
  7. Mock it up on the top case and flip it over and look in the bores to see.
  8. Ditch the spacer plate, and have the porting done for a 4mil, and have proper domes cut.
  9. So what, ive gathered is RU is a retard, with no clues, holsters cocks in his mouth, has a bike that does not run because he's broke, and he is the illegitimate child of Windy and KOC.. Correct?
  10. 95% complete, waiting on air filters, outerwears, and a digi temp gauge.
  11. Black plastics with carbon fiber tank and rad covers.
  12. So do my shocks!
  13. That's next on the list.. Ran out of Banshee $$ for this year.
  14. Wait till i posted pics of the aftermath of spring mud riding here in Michigan!
  15. Engine installed, and wire harness rebuild started.
  16. Thanks man. Don't have the Zilla anymore, sold it 3yrs ago. But, this is it.
  17. Passed leak down perfectly, first time. Engine completely assembled, ready to be installed. 4mil long rod, aggressive dune port, pump fuel, 65.50 fresh bore and pistons, 391cc.
  18. $428 for a bore?! WTF?! Boy, did they see you coming a mile away! Boring of both cylinders is $100 ($50 ea. including chamfering) pistons are $150ish. Who ever is doing your machine work scammed you big time!
  19. Block off is $10
  20. I've got the same deal in my shop, where my bike sits.. when i had my hoists installed i had the guy sink another molly into the floor for me, then i welded and eye bolt in it..
  21. The hub would have too have had the 32mm nut in the center removed. in order for the washer, bushing, washer stack up to be wrong.
  22. Dude, that's pretty fuckin sweet..
