Cub cylinders
NOSS machine cool head
Trinity stage IV 2-1 intake,port matched
V force 3 reeds (little metal emblems on reed cages missing)
Keihin pj carb
Boost bottle modified from dirtbike,has hole plugged on left side,nipple moved,sits real tight against carb
fmf gnarly exhaust,chrome worn real bad along sides,dull from boots rubbing.
Both silencers are dented up on the endcaps
Twist throttle
+ 4 swingarm that someone shaved all tabs off of (skid plate tabs,chain guide mount)so no chain guide
Amp link "holeshot device"
Home built a arms (+6 I think) they sit the shocks at an oddly steep angle,ball joints are welded in place.
Stock plastics with all emblems and holes shaved,uncut,custom paint
Monster energy seat cover,lines up with paint job on plastic.
DG chrome nerf bars,little rust,with no webbing
All stock water pump and clutch covers,just painted green.
14 tooth sprocket
new holeshots on back
+4 axle spacers in back
Brand new,non o-ring gold Renthal chain (still white from the grease)
Was missing:
Mag cover
Shifter
Tie rods (custom length)
One of the torque links/engine mount
It's probably a lost cause,was not registered as I just recently bought it,and had a bent frame,so was in the process of swapping all to a new frame.
Started hard,if it would start at all (carb issues) was just mocked together,nothing was bolted tight. Nothing really stood out,other than maybe combination of parts,and the paint.
