erickson483
Everything posted by erickson483
  1. I got the nuts
  2. Haha I know, it's just hard cuz I've never had this bike assembled.
  3. You're gonna need to list your mods, elevation, etc
  4. It's stock, I'd honestly rather pay for shipping than buy them from my local stealership.
  5. I need the 2 rear axle castle nuts that hold the rear spindles on. My local hardware store doesn't have the right ones.
  6. Look in your clymer and there is a diagram to show where and how to measure. It's in the maintenance chapter I believe.
  7. Are those fucking cup holders?!?!?
  8. Go with a high temp powder or ceramic
  9. Did you connect the choke tube again after you took apart the carbs? I'd check that.
  10. You need to do a leakdown before anything else.
  11. *face palm* holy shit that was painful to read.
  12. Dude stop hijacking every fucking for sale thread and post a damn wanted ad like I said earlier. Or gtfo..,,,that would work too
  13. I'm not really sure what angle you're trying to measure. What section or page are you on in the clymer?
  14. You'll have better luck posting in the WANTED section
  15. Your clymer manual says to slightly toe the front tires in. Measuring from the middle of one tire to the other, the front should measure about .4" shorter than the back of the tires.
  16. Gap should be .018"-.020" if I'm not mistaken
  17. Has anyone made their own brake lines using fittings and line from autozone or any auto parts store? I'm thinking of comparing prices between making some and buying some. Does anyone happen to know what diameter the lines are and what the fitting threads are? Any insight would be appreciated.
  18. Pm sent
  19. For the banshee, why change what works? But what oil do you use? A good oil has no problem at 40:1 but your motor is already broken in with and used to running at 32:1. I'd say leave it.
  20. I got it. I put a floor jack on the crossbar that sits behind the motor and angled it toward the bent part of the frame. I used a 12" piece of 4x4 and pushed that bitch back. Thanks for the help guys, as usual.
  21. I need both rear chain adjusters. I'm located in Howell, MI 48843.
  22. The gap between the flywheel pickup and the little black piece that is attached to the stator. If you pull the stator cover it's pretty obvious to see. Just make sure you measure the gap from the piece attached to the outside of the flywheel, otherwise you'll be measuring a real big gap.
  23. Payment sent. I put my address in as a comment on the payment.
