ionroller
Everything posted by ionroller
  1. Are you sure your jetted properly? If you are staying with a 450 and modded 400 you got problems. Are you running it through the snorkel?
  2. Ill tell you what it would take 150 hp/450lb * 400lb =133.33hp it would take a 133.33hp banshee to be even. And the redline doesn't even start untill 12500 rpm and pulls to 13500 fyi to your fyi to me! Just my 3 cents to the haters.
  3. and will still get beat by a banshee motor It would take a hell of a banshee motor My banshee in my sig is not even a challenge. The 1000 has arm ripper torque and revs out forever, oh and fuel injected works like a dream FYI.
  4. Started a project of putting a 2001 fuel injected GSXR 1000 in a banshee frame. I have my fuel tank under the seat and when my suspension is fully compressed my tank will just about touch the brake caliper! I am 200lb and the motor is at least 100 pounds if not more, so the suspension sags a little with just the weight of the engine. What I really need is a shock 1-2 inches longer so it bottoms before the tank hits something! Ill get some pics up asap of this beast. Its 165HP !!!
  5. can you post a pic of the studded tires
  6. I am in range to pick them up. How much and can you post a pic?
  7. what kind of reg/rect are you using? Stock stator?
  8. you dont need to remove a float. Just drill the hole out a tiny bit bigger and set the floats very high and you will be fine.
  9. What the title says!
  10. Sons of guns is a bad ass show There is more to a silencer than just that though.
  11. step 1 take apart step 2 clean step 3 reverse order of step 1
  12. clean it up and use it. It sounds like you done have a show bike anyway!!!
  13. ionroller
    Goggle's
    Smith Intake or fuel with the quick straps. You can get dual layer lenses for the winter too( I use them for my sled also). I use the light sensitive lens with tear offs.
  14. You are the only one talking shit. People come on here telling you to richen it up before you burn it to the ground and you say I know what rich feels like. You obviously don't. Next time you want to ask a question search, or use your tiny little brain to think before you post!
  15. there called turbine core or turbine core 2
  16. If you think pulling the lid will need 5 jet sizes (280-230=50, which is 5 sizes) then what is your dealers number? must be some good crack. You are way lean like myself and everyone else said, or you cant ride to save your life. Stock banshee's can ride wheelies all day, through 6'th if you know what your doing.
  17. you are way lean. get rig of the lid put in 280 mains and ride them wheelies all day.
  18. lowered my needle 1 clip and it runs great now.. I double checked and my mains are a 165.
  19. Who did the porting? Will them need bored? What size domes, or what was the compression? ( Pump, race gas?) Did they run good?
  20. my press only goes to 5 tons, and I had a axle not come free. Busted the torch out while 5 tons were on it and BANG!!! You will know when it comes loose.
  21. i looked at my plugs after i rode pretty balls out to a friend house, about 2 miles. I pulled in and looked at my plugs and they looked lean. It was running like shit too. Put my air bow lid on and it runs better? I figured I would be at like 155?
