ionroller
ionroller's Achievements
HQ Soldier
HQ Soldier (2/5)
  1. Are you sure your jetted properly? If you are staying with a 450 and modded 400 you got problems. Are you running it through the snorkel?
  2. Ill tell you what it would take 150 hp/450lb * 400lb =133.33hp it would take a 133.33hp banshee to be even. And the redline doesn't even start untill 12500 rpm and pulls to 13500 fyi to your fyi to me! Just my 3 cents to the haters.
  3. and will still get beat by a banshee motor It would take a hell of a banshee motor My banshee in my sig is not even a challenge. The 1000 has arm ripper torque and revs out forever, oh and fuel injected works like a dream FYI.
  4. Started a project of putting a 2001 fuel injected GSXR 1000 in a banshee frame. I have my fuel tank under the seat and when my suspension is fully compressed my tank will just about touch the brake caliper! I am 200lb and the motor is at least 100 pounds if not more, so the suspension sags a little with just the weight of the engine. What I really need is a shock 1-2 inches longer so it bottoms before the tank hits something! Ill get some pics up asap of this beast. Its 165HP !!!
  5. can you post a pic of the studded tires
  6. I am in range to pick them up. How much and can you post a pic?
  7. what kind of reg/rect are you using? Stock stator?
  8. you dont need to remove a float. Just drill the hole out a tiny bit bigger and set the floats very high and you will be fine.
  9. What the title says!
  10. Sons of guns is a bad ass show There is more to a silencer than just that though.
  11. step 1 take apart step 2 clean step 3 reverse order of step 1
  12. clean it up and use it. It sounds like you done have a show bike anyway!!!
  13. ionroller
    Goggle's
    Smith Intake or fuel with the quick straps. You can get dual layer lenses for the winter too( I use them for my sled also). I use the light sensitive lens with tear offs.
