toytech
Everything posted by toytech
  1. do you need sparkarrestors? If so get the turbine core silencers
  2. I had one last summer with the same symptoms, everthing checked out ok, so we started swapping electrical parts and the coil fixed it.
  3. Jeff will steer you in the rite direction
  4. looks great nice work
  5. why are you blind?
  6. x2
  7. higher octane fuel, less timing. plugs back out from detonation. fix it before you kill it.
  8. a good ole boy from Kansas that knows how to make a banshee screem! oh wait you already know that
  9. I cut mine off the front because the usfa stamp is on the back. but then you have to make a hanger.
  10. If I were you I would get the less expensive one and build it to suit your needs. welcome to bhq
  11. thank you we like the heat so thats great. cool I will let you know when our trip is planned.
  12. what is it like temp and riding at sand mountain in august, is it real busy or slow? What is the elevation?
  13. fast racing !!! Jeff is a great guy, and very helpful on tuning if you need it.
  14. we are planing a trip in august to sand mountain
  15. hit up Jeff at fast racing! he will hook you up. I had him do a agressive dune port for a 4mill , I run rocket r2 pipes 35mm carbs, it's a power house you'll love it.
  16. brake cleaner is bad stuff all by it's self, but I didn't know about this. thank you.
  17. get an aggresive dune port and a 4mil crank from Jeff at fast racing, and a set of R2 pipes.
  18. you have plenty of motor for ice racing stock! you need a swing arm 2 to 3 inches shorter than stock to get it to hookup on the ice. my ported blaster would run circle around my shee on ice.
  19. them are some clean pipes for being the old style! great price to
  20. I just put lower arms off from a 2000 on ny 87. I also did the conversion and put the upper a arms on to. the lower arms are the same.
  21. I got my angled filters from fast racing, great price
  22. is the ball still in there with the pushrod? you can also adjust on the pressure plate
  23. I put grease on both sides of the foam gasket
  24. circle auto parts in midland mi
  25. I use grease on mine works great
