one less tooth on the front is not enough for that tire size,ad three teeth to the rear sprocket.
I love the way theese pipes work all around on my banshee.
I can't wait. Brad took it apart when I was there, found one gear with a bushing that was tight and hanging up on the shaft a little. he is working his magic on it now, I am going to pick it up tomorrow morning.
tomorrow my trans will be at Tyson racing to be modded so I can shift it better, not an override though because I trail ride and dune ride.
can't wait to have a banshee that shifts good
check the carb slides one maybe stuck, the tors is working. if the slides are both going all the way down to bottom, disconnect the tors box, should have spark then.
our noise limit is 94db and at silverlake they are very picky and they didn't even check mine with the meter.
so should be good for you.
mine are no louder than my fmfs were.
I had fmf fattys with simular settup and took them off and put on a set of R2 pipes and silencers with toomey 3.0 spark arresters, problem solved with a ton more topend performance.
