I checked the ignition system and every thing seems good as a static test. I trimmed the coil leads but no change. The stator is good doing a static test. the ignition coil is good. I pulled off the carb to check the jets since that is the only thing I didn't pay attention to. The pilot is a 25 and the main is a 280. The clip is on the #3 position on a stock needle. Fuel level is just below the float bowl gasket. The spark plugs are a perfect tan color. And as reminder, he has a stock engine, T5's and a single K&N that splits to the two carbs and has no air box. What do you think about jetting? We're in So Cal at around 1,500ft and about 55f right now. It is only ridden at Glamis too.
