jacquesraney
jacquesraney's Achievements
  1. do i need to fill the coolant resevoir under the seat?? is it for back up???
  2. thanks... well give it a shot... i hope thats all.. it cant be much... i guess thats what happens when you let em sit and not ride....
  3. thanks... well give it a shot... i hope thats all.. it cant be much... i guess thats what happens when you let em sit and not ride....
  4. So my buddy has an 05 .. with Toomey T5's.. cool heads. probably has 10 hours on it... never rides it.. bought new...Well this year he decided to bring it out but is running into a few problems.. Drained all the fuel ..took apart the carbs.. new plugs.. it takes like 20 kicks... then its real sluggish ...then it will run really good and fast..then bog down really low...and this goes on and on... fowling plugs also.. he seems to think it is a float bowl issue because it is leaking a signifigant amount of gas frome the carb tube on the left side under the quad from the overflow tube.. please help!!!!!!
  5. Get er done
  6. How bout some Diet mountain Dew>>>//?????? EhHHH/????
  7. Buy a 'Vespa"... thier round!!!!!
  8. If it has an attatchable beer tap.. Im In!!!!
  9. time is money... to be applied correctly .. i believe items should be blasted with aluminum oxide first... then sprayed..... just my 02...(opinion)
  10. there absolutely has to be some sort of Grenade that is custom and implemented into the theme.. like a brake light cover... or something....!!!!!!
  11. I ordered the packing and the silicone,,, Ive never done this,, how hard is it??? is there a vidieo out there besides a 4- poke???... will i notice a differance??? Also.. was gonna replace my rings... ive had the Shee for 4 years .. runs strong... prolly only put 50 hrs on her.. should i do a compression check and how much for new rings and cool head gasket?????.. p.s. I run vp110 leaded...
  12. I smell a blown engine!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  13. even on terrain thats not just sand,,, hard pack.. some parts of trails.. ??
  14. any one like the sand star tires?? i live in central fl and the trails get kinda loose.. anyone like sand stars???
  15. i have a stock axl.... gettin some rust .. any ideas on how to clean er up,, cheap?
