Pasi S.
Everything posted by Pasi S.
  1. Yes! That is correct. I have 20x11x10 V-paddles and I like them but I would also like to test some haulers or extremes. -Pasi S.
  2. Are you sure that your main jets are not too small? - just asking. If it´s lean it can rev but there is no power to pull it. But I think that you allready know this.
  3. My mod´s are in my signature. My frien has a KFX 700 and I tryed it. It just farts! -Pasi S.
  4. Thank you! sir.
  5. Just want to say Hi!
    You are also "overseas"? Where are you from?
    I´m from Finland, North Europe
  6. Here is my street bike and I love it! Only mod´s are 18 1" holes in a stock air box lid, and my stock Banshee carb´s. Also I have to re-fab the silencer tubes. 15/41 gearing. It´s a 1983 Yamaha RD350 LCII (31K) YPVS
  7. Hmm.... What stroke?
  8. Try it out and let us know how it works! I think it´s not going to be a top-end mod because of the lenght of that "X". I think that there will be atleast enough crossover tube area. -Pasi S.
  9. -better hooking rear tires and gearing. -advance your timing -coolhead to pump your compression -re-port your cyls to have more low-end or get a 4 mill crank and then re-port -port your reed cages and get some CarbonFiber low tension reeds -28mm flat-slide carbs something like that... -Pasi S.
  10. Here is mine. It´s almost stock exept +2+1 A-arms and Öhlins Shocks. In these pic´s I have stock exhaust but now I have T-5´s. I´m happy with it. -Pasi S. ...and I don´t want to cut my fenders!
  11. New spark plugs also! can´t hurt it. I had a fouled plugs and the bottom end sound was similar - almost like 4-stroke LOL!. -Pasi S.
  12. Ok Snopczynski! I will not waste my time... You know... if someone claims that un-ported motor makes 60+ HP, that just makes me feel nervous. My good friend who walked me through my porting told me that I´m going to be mid 50´s. And it´s not just mild clean-up. -Pasi S.
  13. A list of modification I would like to see. Thank you. -Pasi S.
  14. Maybe you can just give that 100$´s to 03Cobra so he can get his carb settings done.
  15. Do it yourself. After that first time you know that it wasn´t so hard. Clean up your bike and let it dry before you do it. Buy a carb-cleaner so that you can clean those carbs perfectly. This way you won´t get your hands dirty and you can focus what you are doing not how dirty your fingers are! -LOL! Learn how to do it! -Pasi S.
  16. I run 21x7-10 Dunlop fronts and 20x11-9 ITP holeshot rears in summer time, and 23x7-10 and 22x11-9 Maxxis RazrII´s in winter time. Gearing with those 20´s is stock 14/41 and with those 22"´s 13/42. I like them both. RazrII´s hook better than those ITP´s IMO. If I were you I would go with 21x7-10 fronts and 20x11-9 rears if you don´t need extra ground clearance. -What else you want to know? -Pasi S.
  17. x2! ..and when people are saying "search and read" it doesn´t mean that you can´t ask things. If you use search you can find your answers in no time and you don´t have to wait. I have been here reading and searching 30minutes to 6 hours in a day almost everyday! I want to know everything about my Banshee!! You are 14 years old, you can read and your brains can handle lots of information - so here you go! BansheeHQ! -Pasi S.
  18. I use purple powerbands and LOVE THEM! more than enough for me! Hey guys... any opinion about that new Hot Triple Boost bottle?? -Pasi S.
  19. What is wrong with your T6´s??
  20. x2 ^^ what he said! -HA! + new spark plugs. Now seriously. If I had a stock bike and 1500 dollars and want to do trails. -tors removal kit -park brake mod. -used set of Pro Circuits or Toomey T-6´s or Paul Turner mids -shave your stock head 0.025 -K&N air filter with adapter in your stock box without the lid -advance your timing +4 or +5 -port your stock reed cages -carbon tech low tension reeds ... -handle bars if you feel so -nerf bars ... - +2+1 A-arms -used set of good front shocks ... - 13/41 or 14/43 gearing with new chain ... -GOOD JETTING ... Port it if you have the extra money! -Pasi S. BTW. What are your current carb adjustments? pilot, air screw, needle, main?
  21. Have fun Jeff!! We all need some time to get our heads to reload. Some good adrenaline shots makes it feel better. Beat the shit out of it and post some pic´s after.
  22. I´m not an expert here and I realy didn´t get what you were asking (hard to translate-lol) but... Stock needles in stock carbs usually works ok. When you make some mod´s to your engine it needs more fuel in different ranges. When you find hard to get your jetting right the problem can be your needles. You can change a needle in an aftermarket or a stock carb if you like as long as the needle is ment to be in that carb. Only thing you have to know is what is your current needle and what part of the needle is not good for your air/fuel ratio. So yes! you can put an aftermarket needle to your aftermarket carb if you like. Carb´s can´t read so they will not know if it´s a Toomey or Alba needle. Ignore all of this if it doesn´t make any sense! Just trying to help. -Pasi S.
  23. Just came back from the local shop. I bought a set of 150´s and 145´s. They didn´t have those 148´s. Also the smallest pilots was 40 witch I already have. Now it´s time to clean my filters and carb´s and see how it goes... -Pasi S.
  24. I´m not an expert - but I´am 100% sure that you can´t hurt your motor just doing one plug test with those 162´s. If those 162´s are too lean you can tell it before you even try to do your test run. When you find out your "perfect" jetting you can go up 1 or 2 size that you can have your peace of mind. When you find out the "good" jetting you can see alot more power. I have 35.5 PWK´s and I have 40 pilot (still rich), needle in the midle and 152 main (still rich). And these settings with 83*F and 300-330ft ASL. Because it will be hot for a long time I will get smaller mains (148,150) and 38 pilots. -Pasi S. (sorry my finglish)
  25. ...you know - when you are holding a can of beer and a smoke stareing something you look more like a PRO! LOL! -Pasi S.
