I have a used Pro Design Billet Cool Head Includes~18cc Small Bore Domes, & Cylinder Studs. You will need a new o ring kit to install this
Part: PDCH-18 THIS COOL HEAD PACKAGE WILL AID IN COOLING YOUR MOTOR WHILE PROVIDING MORE POWER! $165 shipped.
Yes, I ran stock carbs on my 7 when i first built it. Drill them out, cut half of the float off and put a powerjet on it. It will work for a low budget build.
You can replace them, you have to drill the rivots out either way billet basket or replacing the cushions.
http://vitosperformance.com/atv_parts/product.php?productid=11178&cat=184&page=1
Your best bet is to take it to a shop and get it bored and have them tell you what they bored it to. I wouldnt buy anything but wiseco pistons. If you are at 65.5 (1.5 over stock 64) have them bore it to 66 and get a set of wiseco pistons. Banshee stock cylinders only go to 66.5 you are getting close to the end.
http://www.wiseco.com/ProductSearch.aspx
the last 4 digits are the size
we run our 350s anywhere from 6 to 10. I put mine at 10 and back it down until it stops getting hot. ended up around 9. I know everyone is going to bag on me for this but thats what i run on 4 different 350s.
Thanks thats what I was looking for. I had picked up this bottom end cheap and the crank was in it. Took it to metaltech and they said the rod and bearing are good. Fully rebuildable
Can someone tell the difference between the 4 mil +5 rod and the 4 mil stock rod. Logic tells me moving the rod 4mm is 4mm no matter how long the rod is. A longer rod will raise the piston but still have the same stroke. Then you put stroker or blaster pistons in it to lower the top of the piston down. I'm confused! I get the less stress on the sides but what about power? more less same?
Do you really think someone is going to read this thread and buy that motor from you? You are high you couldnt even give it away now. And when you reply all worked up take a deep breath and type slow so we all can read it. You get all bent out of shape and dont type in english then its harder to laugh at you. This has to be a joke!
The only thing I dont like about the pj is the idle ajustment is on the chock knob. And i've heard that ajusting it that way will lean out at wot. The pwk has a set screw for the slide
