uwenr
Everything posted by uwenr
  1. updated list please text 602-478-5307 CPI BIG BORE SMALL FLANGE BOTH OUT LEFT BLACK $325 DOUBLE BUFF MOHAWKS 10X5 DOUGLAS BLUE LABEL $125 CHROME CLUTCH COVER WITH BILLET INSERTS AND DIPSTICK $150 CDI/REGULATOR WITH HARNESS, HARNESS IS HARD WIRED FOR NO KEY, NO KILL SWITCH, AND NO LIGHT SWICTH. $75 COIL $50 SEAT $50 PLASTICS BLACK, FRONT, REAR, TANK COVER ALL DRAG CUT $50 BILLET BAR CLAMP $20 REAR BRAKE CALIPER WITH BILLET BLOCK OFF $30 TANK WITH DUAL PINGEL AND BILLET CAP $100 RADIATOR WITH HOSES $40 SPINDLES DRAG CUT, NO FRONT BRAKE SET UP $40 REAR HUBS $30 STOCK CHROME SPROCKET HUB $30 STOCK FRONT SHOCKS WITH CHROME SPRINGS $65 STOCK TRANNY WITH DRUM $75
  2. i appreciate all the good responses, it was good dealing with everyone. I try to be as fair as possible with pricing and description.
  3. stock tranny is completely stock
  4. Updated list before i put the rest on ebay CPI BIG BORE SMALL FLANGE BOTH OUT LEFT BLACK $350 FRONT A ARMS STOCK CHROME $250 DOUBLE BUFF MOHAWKS 10X5 DOUGLAS BLUE LABEL $125 CHROME CLUTCH COVER WITH BILLET INSERTS AND DIPSTICK $175 2 THRU 5 OVERRIDE $300 CDI/REGULATOR WITH HARNESS, HARNESS IS HARD WIRED FOR NO KEY, NO KILL SWITCH, OR NO LIGHT SWICTH. $75 COIL $50 SEAT $50 PLASTICS BLACK 2 SETS $50 EACH BILLET BAR CLAMP $20 LONESTAR AXLE STOCK SIZE NOT BILLET $100 REAR BRAKE CALIPER WITH BILLET BLOCK OFF $40 TANK WITH DUAL PINGEL AND BILLET CAP $100 RADIATOR WITH HOSES $40 SPINDLES DRAG CUT, NO FRONT BRAKE SET UP $40 REAR HUBS $30 STOCK CHROME SPROCKET HUB $30 STOCK FRONT SHOCKS WITH CHROME SPRINGS $65 STOCK TRANNY WITH DRUM $75
  5. Revised list and link to pics http://s253.photobucket.com/albums/hh67/uwenr/banshee%20parts/ CPI BIG BORE SMALL FLANGE BOTH OUT LEFT BLACK $350 FRONT A ARMS STOCK CHROME $250 DOUBLE BUFF MOHAWKS 10X5 DOUGLAS BLUE LABEL $150 CHROME CLUTCH COVER WITH BILLET INSERTS AND DIPSTICK $200 2 THRU 5 OVERRIDE $300 CDI/REGULATOR WITH HARNESS, HARNESS IS HARD WIRED FOR NO KEY, NO KILL SWITCH, OR NO LIGHT SWICTH. $75 COIL $50 SEAT $60 PLASTICS BLACK 2 SETS $50 EACH BILLET BAR CLAMP $20 LONESTAR AXLE $100 REAR BRAKE CALIPER $40 TANK WITH DUAL PINGEL AND BILLET CAP $100 38mm PJ CARBS CONVERTED TO ALKY $350 RADIATOR WITH HOSES $40 SPINDLES DRAG CUT, NO FRONT BRAKE SET UP $40 REAR HUBS $40 BRAKE PEDAL CHROME WITH CHROME SPRING $30 38mm BOSS SEPARATE INTAKES $75 MARVIN SHAW FRONTS $150 STOCK CHROME SPROCKET HUB $40 STOCK FRONT SHOCKS WITH CHROME SPRINGS $75 STOCK TRANNY WITH DRUM $75
  6. SOLD front hub rear shaw
  7. picture link to my photobucket http://s253.photobucket.com/albums/hh67/uwenr/banshee%20parts/ SOLD stator cover kicker shifter 4mm crank milled head small bore cpi
  8. i will take pics tonight and dump them into photobucket and post the link. Too hard to post that many pics.
  9. prices are OBO, I live in Phoenix so shipping is not included. Text 602-478-5307 or PM will consider some trades, looking for HS plastics, Shearer big bore small flange out one side CPI SMALL BORE RAW BOTH OUT THE LEFT $350 CPI BIG BORE SMALL FLANGE BOTH OUT LEFT BLACK $350 FRONT A ARMS STOCK CHROME $250 DOUBLE BUFF MOHAWKS 10X5 DOUGLAS BLUE LABEL $150 9 PADDLE DOUBLE BUFF HAULERS $150 +8 METAL TECH OVAL TUBE SWING ARM CHROME W/ CARRIER & LINKAGE $350 CHROME CLUTCH COVER WITH BILLET INSERTS AND DIPSTICK $200 BILLET STATOR COVER $80 2 THRU 5 OVERRIDE $300 CDI/REGULATOR WITH HARNESS, HARNESS IS HARD WIRED FOR NO KEY, NO KILL SWITCH, OR NO LIGHT SWICTH. $75 COIL $50 SEAT $60 BILLET SHIFTER $15 PLASTICS BLACK 2 SETS $50 EACH BILLET BAR CLAMP $20 LONESTAR AXLE $100 REAR BRAKE CALIPER $40 CHROME KICKER $20 TANK WITH DUAL PINGEL AND BILLET CAP $100 4 MIL CRANK WITH STANDARD RODS $200 MILLED HEAD WITH CASCADE SMOOTH AND POLISH $75 38mm PJ CARBS CONVERTED TO ALKY $350 RADIATOR WITH HOSES $40 SPINDLES DRAG CUT, NO FRONT BRAKE SET UP $40 FRONT HUBS DRAG CUT CHROME $40 REAR HUBS $40 BRAKE PEDAL CHROME WITH CHROME SPRING $30 38mm BOSS SEPARATE INTAKES $75 MARVIN SHAW FRONTS $150 MARVIN SHAW REAR $150
  10. i three stock springs and 3 hd springs. Also different disks, i think they are for a R6.
  11. do you have pics? any chain break?
  12. it has to be a 05 or newer blaster, the hubs are not the same on the older blasters.
  13. Would you be willing to part with one set of the paddles with or without wheels?
  14. yes $75 shipped
  15. i have a set Keihin 38mm pjs honed to 39mm, converted to alky with Mikini power jets. $200 for carbs $75 for intakes, Boss separates Also parting out the 350 in signature
  16. I have a set of CPI small bore small flange out of frame pipes. They are raw and out the right side. No dents or dinges. $300 shipped. Also parting out 350 bike in signature except the cylinders and cases.
  17. X2 the lobe is on the wrong side, the chain is loosening it. Spin it 180
  18. Cases need to be trenched for a 7 mil
  19. I have a set of TDR and Marvin Shaws fronts that are like 12 1/2
  20. I cut all my pistons, you can raise the intake window to match the intake of the cylinder.
  21. I know this is off topic but Loco that chick in the middle of your sig is smokin hot
  22. just my 2 cents sounds like you're running out of fuel at WOT. Have you checked the plastic screen on the pingle in the tank?
