tedd1
Everything posted by tedd1
  1. I assume you are OK with the honest thieves?
  2. Should be a hose between the carbs
  3. Slides in correctly? Little hose between the carbs? Floats adjusted properly? Carbs full of metal shavings?
  4. The OP has a stock motor with pipes and filters.
  5. This is right out of the Yamaha manual. As long as the oil is rated SE, Yamaha says it will do the job. And, put the idle screws in...
  6. Tim is a supercub specialist...
  7. tedd1
    Flywheel
    Found one! Thanks!!
  8. tedd1
    Flywheel
    LMK what you have, please.
  9. if your cylinders are already ported, probably be better to go with a standard piston.
  10. Should give you an idea what you are missing.
  11. >HERE< ya go!
  12. Yes >HERE< is how...
  13. Direct Drive Good people, they will do what it takes to get you what you need.
  14. Yes, just conect those two wires to a simple on/off switch. If it runs now, the red/black wire must be grounded already.
  15. I am planning on going but, as of today, still have motor parts scattered all over the country.
  16. A 9 volt battery will run a dozen LEDs all night. I have seen some use a rechargeable battery pack like the ones used for drills.
  17. Look >HERE<. Saturday, Feb.23rd is TNT day. Racing season starts Mar. 9th and runs 2nd Sat. every month till Nov.
  18. Close the PJs a round or two.
  19. What do the super cub pipes look like? Chrome? Same side?
  20. It is all about the set up. A motor don't care whether it is running 300' or 3000'. The thing about a cub is that it is very good off the shelf and is very forgiving on tuning. Most of us don't want to take time to tune, we want to bolt and go.
  21. Divide the big one by the small one. 15 x 45 = 3.0
  22. I got my hood from Jared a couple years ago. He can and will work with you on design and colors. Have him get you a hood already cut and paint it up the way you want it. These guys put out quality stuff. They are talented artists and skilled body men.
  23. tedd1
    Builders Race
    Wow, the secret is out...
  24. tedd1
    Builders Race
    I build my own
