tedd1
1 Follower
About tedd1
  • Birthday 02/27/1956
Contact Methods
  • Website URL
    http://
    TEXAS!
Recent Profile Visitors
3,562 profile views
tedd1's Achievements
HQ Soldier
HQ Soldier (2/5)
2
  1. I assume you are OK with the honest thieves?
  2. Should be a hose between the carbs
  3. Slides in correctly? Little hose between the carbs? Floats adjusted properly? Carbs full of metal shavings?
  4. The OP has a stock motor with pipes and filters.
  5. This is right out of the Yamaha manual. As long as the oil is rated SE, Yamaha says it will do the job. And, put the idle screws in...
  6. Tim is a supercub specialist...
  7. tedd1
    Flywheel
    Found one! Thanks!!
  8. tedd1
    Flywheel
    LMK what you have, please.
  9. if your cylinders are already ported, probably be better to go with a standard piston.
  10. Should give you an idea what you are missing.
  11. >HERE< ya go!
  12. Yes >HERE< is how...
  13. Direct Drive Good people, they will do what it takes to get you what you need.
  14. Yes, just conect those two wires to a simple on/off switch. If it runs now, the red/black wire must be grounded already.
  15. I am planning on going but, as of today, still have motor parts scattered all over the country.
