Bansh-eman
Everything posted by Bansh-eman
  1. dajo correct me if im wrong, but a stock cylinder cant make it to 68mm and still have bore left? i think you can only go out .080 and thats a gernade waiting to blow... unless he had some work done to fit a new sleeve i dont think its a 421.. a 396 is more likely...
  2. i miss read your post i thought you wanted the torque spec for the locknut, the hubs dont have specs i dont think... just run them up until your hubs dont wobble then go one more notch and pin it...
  3. your probly going to lose a very small amount of power running 118 oct with 160 psi, it will run cooler but its going to be harder for your motor to ignite it. im sure you will be fine running it and the amount lost will be so small you wont really be able to tell but like i said your compression is more around 110...
  4. you need a flywheel puller ($15) pull the wheel off... remove the screw holding the wires down... use a small socket (8mm i think) to take off the old plate... remove the stator abd mount it to the new adjustable plate. use the case halfs to set your timing... and tighten everything back down...
  5. Bansh-eman
    glamis
    we can just meet out at olds... come find me and polish on sat at the store.. and we can work something out...
  6. your going to be wasting alot more money if you try to run pump... and when it blows up remember i told you so... or if for some crayz reason you get huge dome so you can run pump your going to realize you wasted 1200 bucks...
  7. a stock banshee calls for just regular 10w30 motor oil... im sure its the same stuff, only reason ppl run the 80 weight is when its hot you dont want it to think out so much that it runs right off your shits... you want it to still have some thinkness so you dont have so much metal on metal...
  8. Bansh-eman
    glamis
    i bet its going to be packed like crazy now....
  9. whats the point of getting a cub if your going to run 22 or bigger domes and try to run pump gas? you basically building a dragster but you want to putt around on it... a 68 bore with 18s or 19s your going to have well over 170psi no way your going to run pump gas... if your going to spend money on a cub and run bigger domes you might as well stay stock jugs and get you a agreesive dune or drag port...
  10. 110 in elcajon is 6 bucks a gallon
  11. oh im not saying you cant run pump but your motor isnt going to last long... if your getting 68 bore your compression is going to be so high your going to detonate the crap out of pump gas...
  12. lol you be the one to put some cubs on and run pump gas... let me know how long your pistons last much less try to climb olds.... cubs are made for high rpms wot ... not putting around in 2nd gear... you would be a fool to run anything but race gas... your wasting your money... if you want to run pump then you might as well stay stock and get new reeds asvance your timing and pod it
  13. Bansh-eman
    glamis
    throw it on there for sat at least... if as many ppl show up as claim theres going to be a bigass turnout and your not going to want to stay at the store once we bounce...
  14. that bike would kill rippin up olds! if your wanting to run pump dont get a cubby lol... if your going to spend all that money and put small domes on it your wastig your time.. stick with some 20's or smaller... after i sell my house and move back into military housing im getting me a set of cubs... youll see me rippin up olds like its going out of style..
  15. lol you got zomg-wtf-pwned-bbq
  16. Bansh-eman
    glamis
    im sure someone goig will have a redneck bike with a six pack rack lol throw a small can on there and your good...
  17. Bansh-eman
    glamis
    lol dude i thin you can make it out there just dont go balls out over every hill and waste your gas...
  18. check the stop things on your stem under where your pipes are at... they should hit the metal when turned all the way...
  19. you wont need the oversized radiator... get your self a billet impeller and runs distilled water and redline water wetter and you will cool fine...thats 400 bucks you can put else where
  20. i got mine from here ims tank they are out of riverside somewhere... call them and ask if you can comeby and pick it up save in shipping... only tooks like 2 or 3 days to get to me in san d
  21. i rode a 3 wheeler like 2 times once i got going to fast and the bigass bubble tires started bouncing me and i plowed into a tree i decided a tri-c isnt for me
  22. damnit dad! you went and ruined my fun lol i was going to unleash the dogs lol... ohhhhh shit son what that pimpass ride ! FUNNY VID
  23. u can just referr dajogejr as dad lol he will be on more posts te you can imagine! as said welcome aboard... you just got your self an addiction worse then black tar...
  24. yup that what we are here for :beer: cant wait till thursday we are going to have a blast!
