Bansh-eman
Everything posted by Bansh-eman
  1. the mp cables blow... polish had the steel braided and when they got hot the inside material came undone and cause his clutch top be hard as balls to pull... as far as the lever i only had it a fe month but its smooth has a little up and down play in it but not much.. its better then the stock i had for sure...
  2. yea they are this big [---------------]
  3. yea as you can see my math really kicks ass i couldnt even add it up my self... dont quote me on the .020 over is .5 mm but i think thats right... someone will chime in once they read this.. like i said befor i cant ever remember.
  4. best part of the drags was as soon as we got there the hot chick in the tube top was bustin up the drag! titties bouncing lol
  5. your a fool if you think 200 is where to start running race gas...
  6. same here... need 6 bolt steel only!
  7. i got a motion pro ez pull lever and perch im selling...pm if interested...
  8. stock bore is 64mm... 65.5 is .080 over i believe... cant remeber if ever .5 mm is .020 or not i always forget..
  9. ebay has a guy that sells chromed one for 550 shipped... the 460 ones are not chrome
  10. 185 psi and 50/50 your taking a chance... that high of comprssion ytou should be running 110...
  11. hey silence check your compression tester... i was thinking about it and your motor dosent have a stroker and you on a stock bore with 21 domes right? if so your tester might be off seems really high for that motor....
  12. strip is about as wide as a football field... but it dosent go straight casue jack asses start moving in and making a cone so they can see.. me and polish where talking about the buddies losin control too... thats why we camped right at the start of it... i was hoping that stupid fuck broke that thing! we where out in the closer this time, went right past chinawall and we got WAY out there and noticed the sand was super soft and not a single track on it....
  13. i bought my bars and a sticker set of chase, hes a pretty straight foward guy he wont dick you around. if he said he shipped it , it was shipped, just give it some time.
  14. try using the blunt side of a knife and scrap it off.. i had duct tape on mine and my buddy got damn near all of it off.. they looked brand new!
  15. well i just got home from riding and im not going to look for your other post so im just going to wing it here and leave my respones.... from the way it sounds you where running rich and need to change jets? if so the jets are in the bottom of your carbs... take the silder out the tops and remove your fuel lines.. loosen the clamps and pull your carb... flip it over and the four screws on the bottom pull them off, fuel is going to dump out when you flip it so dont be in your house the main is the one that looks like a hexagon, the pilot is in a small hole right next to the main, you need a small flat head to get it out. and your needle is on your slide. to pull that compress the spring and slide your cable out of the small groove in the slide and it will come off the cable... get your phillips i think is what they are on stockers and turn it out and your needle will come out...
  16. well guys i had a horrable weekend at the start so i didnt get much footage to make a nice video... ill post what i got but im not goig to spend much time cliping it and what not most of it buggies at the sand drags..
  17. dont feelbad i think this was a bad weekend for everyone! my new carbs didnt work and i had to drive back to san diego to get my olds ones... and a fellow hq'er had hell with his stator! oh and almost forgot jokerswild had his shock come un screwed and luckly didnt break anything casue we took the raod back to camp and not the dunes...
  18. i know no one reads the swap trade so im posting here too. trading Motion Pro Turbo twist throttle with cable and spider grips looking for a nice tumb setup pref with a billet extender and cable... let me se what you got and see what we can workout...
  19. looking for a nice thumb setup with a billet extender and cables trading Motion Pro Turbo Twist with cable and new spider grips
  20. Bansh-eman
    glamis
    ok guys last post ....see you out there BEACH STORE SAT 9 AM !!!!
  21. Bansh-eman
    glamis
    nope no gas ot there... your going to need to get another can... dont waste 30 bucks and get a vp can... go to walmart and get a gas can they are lke 9-12 buks... i have 25 gallons as well and like he said i think by sunday im going to be doing ALOT of nothing...
  22. almost every aftermarket clutch perch you have to remove it any ways..
  23. instead of doing a hide-a-key... eliminate your key all together... follow your key wires down to the plug... unplug it and the bottom half of the plug should have 2 wires... cut the plug off and splice the two wires together... get some liquid tape at walmart... and use that to seal the wires so no dirt water or anything gets in and it dosent short out on any metal... and your good...
  24. 21? hummm we looked online and 33-36 are 16mm. what carbs you have? my 34 PJ's are set at 16 and i just put my new 35 PWKs on tonight and set those to 16 as well...
