Bense
    So Cal
  • Interests
    Drag boats and Banshee's
Bense's Achievements
  1. Nevermind thanks guys. Called trailtech another 4 or 5 times. Finally got someone on the phone instead of the automated message. explained to them what was going on and the are hooking me up. Glamis is on.
  2. Called rocky moutian and trail tech and they won't replace it. pretty pissed off. Going to keep trying but I went online to search part number and am having difficulty finding the light at a page that is not Japaneese. It says Phillips brilliant line Part number xxxxxxxxx (i am at work and don't have it) 35watt setup. Is one a spot and one a flood? HELP THANKS BENSE
  3. What are you running and where did you get it?
  4. You def want to replace the powerband its the first mod I did, but what everyone forgot to tell you on here is you don't want to put them in dry. they will lock up on you. You need powerband oil its kinda like shock oil and make sure you get the sythentic stuff. Its common sense but sometimes its not so common. They are right next to the modulator valve if you are having a hard time finding. Call your local atv dealer and they will hook you right up.
  5. If you want out of it. i will give you 1200. I live in So-Cal. Send me a PM or call me on my cell if interested. 626-991-8776
  6. I will be out there this weekend. Leaving thursday night or fri morning. Might be in Gecko or might be at Road runner. Couple banshee's and a lot of other bikes. Think there will be about 25 of us.
  7. Bense
    glamis
    Sounds like fun..We are cruising out next weekend with a few banshee's. if anyone will be out there next weekend the 4th...lets get together.
  8. NEED A GOOD DUNE PORT. ONLY RIDE GLAMIS
  9. Thanks guys. Actually my buddies ex-girlfriend still has her banshee at my buddies house all taken apart. I think we may pull a float swap :biggrin:
  10. Yeah stock carbs at 21mm. I need to pick up a set of 33's. Nos head 19 cc domes, T-5 pipes, timing advanced +4, K&N, V-force 2's
  11. So after putting the right float (only) in the left carb, it doesn't leak. I kept the left needle and seat in the left carb, just installed the float as a test. NOW anyone know what these run? Calling my yamaha dealership tomorrow.
  12. Alright here is the deal. I have had the carbs in and out 5 times tonight. Its not a grain of sand, something has to be a little tweaked on the float. Its flowing out of the left (choke side) carb. My buddy came over that is motorcycle mechanic and was looking at it as well. He also can't figure out whats up. I think I am going to go out, pull the carbs off again. Pull the float off the right carb, and put it on the left carb and see if that seals it. If it does, then I need a float. If not, then who the fock knows. We even pulled the needle apart and the spring is working like is should. We thought maybe a hole in the float making it heavy and not shutting it off, but thats not the case either. I build drag boats and very mechnical and this one has me stumped, if this was a big block chevy I wouldn't have this problem. Off to troubleshoot more. Anyone has any ideas feel free to toss them my way. Thanks. Oh yeah they measure 21mm or very close with the gasket off.
  13. Thank you much. I am going to head out and measure them. Last weekend I was dropping a cylinder, and I think its due to this problem fouling a plug.
  14. I'm dripping fuel, hard to start. I had the carbs apart and cleaned them well. Put it all back together and same thing. Plugs are wet. Taking them apart again to check needle and seat but anyone know the stock carb float measurement. I know to turn it upside down and measure. THanks Oh and yes my chocke tube is in place. :biggrin:
  15. Good question. Would like to hear more about chains.
