Bansh-eman
Everything posted by Bansh-eman
  1. thats nothing compired to race gas here.. its over 6 bucks a gallon ( that was last year) this year its probly over 7
  2. that sux that the game is that short, but screw it i want to play online anyhow
  3. thats great and all but do him a favor and drop this in his feedback link on anypost he has made. makes it ezer to track for everyone
  4. unless you let it burn all the oil out you shouldnt have much carbon. if for did let it burn all off and have alot of deposits you can try cleaning it off with a green scotch brite pad but its going to take alot of elbow greae to break it free.
  5. ok first off your a tard for putting 10w30 in there, you dont need to put anything how ever on new cranks its not a bad idea to pour a little PREMIX oil on the bearings for the rods. do your self and that motor a favor and take it aprat and drain it out and flush it. that oil is not ment to be burnt up like premix. your going to make huge deposits of carbon and probly shorten the life of the motor by being lazy. open her up and fix it and just be done with it.
  6. if you look at the placment of the stock fenders they arent going to deflect much, they sit to high. i cut my fronts and rears and have 0 problems with debris. now i also ride only n sand. not sure how it would pan out in mud/water but id assume the same.
  7. not in taiwan
  8. the veteran is no fuking joke, u get hit 2 times nd your done. and they are everywhere.
  9. 379 an ez way to determin bore is: bore(in mm) x bore (in mm) x length of stroke (in mm) x .0007854 x the number of cylinders stock bore is 64mm stock stroke is 54mm so a 68 mm 4mil would look like 68 * 68 * 58 * .0007854 * 2 = 421.2759936 please use the search next time there is a post that is pinned at the top with this info
  10. i downloaded the demo for pc, i upped the shaders and all that... all i can say is holy fuck!!!!
  11. there isnt a need for that bolt. if you got an aftermarket swing u already got a zerk if your running tock you can fill the swinger pivot with grease before installing. and unless your riding in soild mud or water then you will be good for well over a season.
  12. reeds will improve your throttle response
  13. if your motor is out of the frame ad youhave someone steping on the strap wrench it would be very ez. in the frame holding it by hand its going to be harder. im sure you can get it to work but its not going to be simple. try finding someone close to you that has an impact and just buzz it off
  14. you can probly just put stiffer springs and that will fix your problem. the fzr fibers ar just strong fibers that wont burn up as ez, and will grip the steels better
  15. make sure you use a little grease on there when pulling it off.
  16. you should have asked him why alot of drag racers run them if they dont work. yup its the same thing
  17. all years are the same. im looking online and they are showing 3 differant plates in th clutch... let me grab the part # for u one sec part# 4H7-16321-01-00
  18. man dosent seem like an even trade?
  19. i really want to play this on 1080p tech. but i think im buying this shit for my computer. too bad you cant cross over to the ps3 or xbox players!!! you guys are tech nerds what kind of differance am i looking at? i got a amd 3200+ 64bit cpu, and a gforce 7800gt with 1 gig ddr would the ps3 blow it out of the water ? also brad are you using the controllers or can you plug in a usb mouse and keyboard to play?
  20. a cheap thai hooker that washes laundry
  21. oh you only had a total of 3? the way that it read was you got 3 with one piston
  22. Half and half just makes it a little ezer to pull the lever. I have heard some good and some bad stories from tusk clutches. I have never used one though so I can
  23. i tired telling him about those pirate hookers but he didnt listen, know see what happened!
  24. pop it out pop a new one in. if you dont want to drain the oil tip it up on its side a little.
