IROOST1
Everything posted by IROOST1
HEB, your inbox is full Does 5 bucks sound good. I'll stick em in an envelope. Just want to make sure you know the needles are for mikuni's. The 50 pilots are currently in one of my banshee's. sorry. if you paypal me, i can send them asap. dave
Any one replaced their ball joint boot?
IROOST1 replied to peterlocal22's topic in Banshee Repairs and Mods
i safety wire mine on instead... -
Its located in carol stream, illinois
i know i have one upper a arm bolt, ill have to look for another. pm me
i have brand new stock needles out of my moose rebuild kits. I may also have the 150 mains but i have to check, pm me.
Email Me for Pics @ [email protected] Red Plastics, Silver Frame Runs Good, Looks Good 1999 Yamaha Banshee with clear illinois title 2001 Motor Fresh Rebuild with new crank trued and welded Fresh Cylinders are .020 over by Eric Gorr Stock Porting New Wiseco Pro Lite Pistons Stock Head NGK BR8ES Plugs with New NGK Plug caps New Rubber Intake Manifolds Aluminum Boost Bottle TORS Removed with Motion Pro Throttle Screws K&N Filter with Filtercharger and Pro Flow Aluminum Airbox Adaptor BILLS Pipes and silencers (flat black) Gold DID Chain DG Aluminum Nerf Bars DG Aluminum front bumper Renthal Barpad New ProTaper Grips YFZ 450 Front Master with polished aluminum lever New Brake Pads, cleaned and greased brake components Aluminum Quick Adjust Clutch Lever Douglas Red Label Front Rims(85% tread) ITP polished aluminum rear rims with maxxis razr mx's(95% tread) New Seat Cover Billet E-Brake Blockoff Shockwears shock covers All suspension/chassis pieces cleaned and greased New A arm bushings New Radiator hoses I will also include extra main jets, pilots, needles. I will also include a beat up set of white fenders.
welcome to the club, thats why they have the tors unit. i think it has more to do with the stock carbs. I switched to pwk's to eliminate the wot sticking.
like it says. need it to change my long rod stroker out so its easier for my girlfriend to ride. i pay paypal. let me know what you have. thanks
yeah, i got some, they are nice. you can check out their website. www.billspipes.com
I have tried everything on this subject including ruining a clutch basket gear by jamming shit inbetween the gears. Dont do that. Either go to yamaha and get the tool or make your own out of old clutch plates. I made mine with three fibers and three steel drilled through and bolted together. Works great. Ill send you mine for $20 shipped or ill send you some old plates to make your own for $7 shipped. Also, get yourself a torque wrench. Its the only way to get it right. I have tried the air ratchet to get it. It only gets it to about 40 ft lbs before the whole thing spins.
Yeah, theres something off. Why did you raise the floats? THey should be at 21-22 mm when upside down from the carb ledge to the top of the float. Or read your repair manual on float adjustment. I had the same problem with my one carb. It turned out to be a bad needle jet and seat. I had the moose carb repair kits and the one was just bad. Just make sure everything in the carb is in place. Theres not much to a carb so good luck!!!
I dont think my stator is working correctly. How can i check it to make sure it has enough output?
the pwk's are keihins. they use a completely different set of mains and pilots than the mikunis. I dont know what main to recommend since i havent installed my pwk 28s on my shee but my blaster is at 55 pilost, 162 mains with a pwk 28. get an assortment of mains and pilots so you can just play around. denniskirk.com is the cheapest for the high quality mains and pilots. or vitosperformance.com is good priced too.
picking up a blown up blaster for 100$
IROOST1 replied to 2004LEBanshee's topic in General Banshee Discussion
Good Deal, i just picked one up last month for 175 bucks with a title, just needed a top end. So far, it got a new chain, a 28pwk, new cables, new levers. And soon it will have hydralic disk brakes....... -
ANYONE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! I have it at 55 pilot and 2nd clip from the bottom but it still seems off.
Its called TIRE IRONS. Get some good ones with good handles. Also, a cheapo bead breaker(or set your car on it). Once you get the hang of it, its about 5 mins to dismount and remount. You will need a good air compressor to seat them and about 40-50 lbs of pressure to seat them. Also, a bottle of soapy water helps seat the bead(spray it down)
i need a blaster silencer that is rebuildable, unlike the stock crap.
chest protectors are great. i never ride without one. i have crashed so hard that the rivet in the shoulder part indented a scar in my arm. also, i hit a bigass tree branch in the woods that tore me off my yz250 at about 40mph. it cracked the chest protector and my arm was sore but it saved me from breaking something. i have one now that has an alien on it, i think its ufo. its nice and i barely know im wearing it.
where should i start jetting a 28 pwk on a stock blaster. Fresh top end, .25 over, 150lbs compression cold. the only things im doing to it is a pod filter and a new silencer. i am thinking 50 pilot and 162 main to start. any comment, please post.
that seems rich on the pilot and lean on the main. i ordered a variety so i have 45-52 pilots and 142-172 mains. i was thinking 48 pilots and 160 mains but ill try the 52 and 152.
i am installing 28 pwks and am trying to find a new cable. i have one that will work but its old. and the new ones have the fittings for the tors. what cable am i supposed to buy?
i am switching to 28 pwks on one of my banshee's and want to know a baseline jetting to start at. vitos pistons stock porting coolhead, 19 domes alum airbox, no lid k&n filter boost bottle fmf gold series pipes 110 race gas, 50:1 amsoil 800 ft above sea level 75-80 degrees about
how much can i make parting banshee
IROOST1 replied to IROOST1's topic in General Banshee Discussion
sorry about the pics not working. i thought they were, ill try and get some up. -
But what should i expect to get from mine? http://i193.photobucket.com/albums/z208/ir..._0504KI0004.jpg i have 2100 into it, would i get that back or not. I sell shit on ebay all the time, shipping is not a problem, i take(steal) boxes from work and the post office picks up right from my house. which place is the best to part it, ebay or hq? also, back to the first question, do it whole, semi part it, or every nut and bolt part it? -
heres a pic http://i193.photobucket.com/albums/z208/ir..._0504KI0004.jpg
