gregbowler
Everything posted by gregbowler
  1. Maybe this will help:
  2. I would say 220-240ish
  3. The needle with 6 notches is aftermarket. The one with five is the stocker.
  4. The middlle roller in the first pic. The one the swing arm pivot bolt goes through. Use one like this: http://www.rockymountainatv.com/viewLarger...s_06_14802b.jpg
  5. When I called they said they are +2 +1
  6. They said they ordered them chrome from whoever makes them and they got black so they sent them all back to be fixed. So for now black or silver. I'll call tomorrow and talk to someone else. Anyone else ?
  7. I am going to buy the Rec front end from alba. I called them and they said the don't have the arms in chrome any more. What color should I get them in Black or silver ? (stock silver framed bike) Also wondering what I should put into the field for type of riding. I trail ride as well as dune ride. Should I get the dune editions ? (same price as non dune edition $749) Here are the kits I was looking at: http://store.albaaction.com/shop/ATV-YAM-BAN.html
  8. You can use A/C power. Read This: http://trailtech.net/vapor.htm
  9. Look Here: http://www.yamaha-motor.ca/products/produc...=A|&LANG=en
  10. http://cgi.ebay.com/ebaymotors/Yamaha-350-...sspagenameZWDVW
  11. Don't forget the DMC 916
  12. http://cgi.ebay.com/ebaymotors/yamaha-bans...065370952QQrdZ1
  13. I've got 20-10-10 10 paddles and can pull 4th all the way up sand mt NV
  14. Just swap in some real gaskets.
  15. I have the same pipes with the following mods and run a 300 main and 27.5 pilot DMC 916 pipes K&N with proflow and no lid +4 timing Lightened flywheel Carbon tech reeds in the stock cages Stock bore and head Elevation 3500ft (sand mountain nv) 40F-80F temp Also see Here: http://www.dmc-on-line.com/AlienPDF/Banshee916_System.pdf
  16. That would be great
  17. get an old suzuki lt-80. When they get older you can mod it with a pipe ect.
  18. http://www.rockymountainatv.com/productDet...mp;navType=type
  19. I'll be there holloween with about ten other friends
  20. lean backfire ?
  21. Black is the ground green is for the low beams yellow is for the high beams
  22. I run the renthal honda 400EX bend bars on mine. They're a little less pull back and a little taller than stock.
  23. Here's the UPP kit : http://www.magicracing.com/UPP-Chain-Slide...p_703-1058.html
